Old 02-21-2023, 08:44 AM   #1
2022 30' Flying Cloud
DFW , Texas
Furnace Cycling Issue
I have an Atwood AFMD30 furnace in my rig that has been having new issues with cycling.
The blower runs for 5-10 seconds before the igniter fires like normal. It lights after the first click. After a short interval, I hear another click and the flame stops before the furnace clicks again and reignites. The blower runs continuously through this process, but might cut out for a split second very periodically.
Anyone have any ideas as to what the problem is? I've swapped over my propane tank to a full one, so that's not the problem.
hawkspur is offline   Reply With Quote
Old 02-21-2023, 08:51 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Maybe the overtemp sensor is bad?
Chris
Old 02-21-2023, 09:06 AM   #3
Boxite's Avatar
2008 22' Safari
Spider webs or other obstacles can cause local overheat spots.
Old 02-21-2023, 09:10 AM   #4
DFW , Texas
I've checked the exhaust tube and I don't see any obstructions. I've also checked the furnace compartment and I don't see anything obvious.
I just shot some canned air into the blower area but that didn't resolve the issue
Old 02-21-2023, 09:14 AM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Have you measured the air temp from the closest outlet to the furnace while the furnace is running. If yours only runs for a short time this may not show much but if no heat is coming out goes to air flow problems.
Can you look at the furnace control board, does it have a red fault code light. Might want to look at it right after a failure. If flashing compare flash count to chart on furnace somewhere.
Again looking at the furnace wiring in general does yours have any Scotchlock type connection tees? These tap into a wire run and connect another to the wire run. I’m Not a fan of their use.
Does range burner run normally?
Gary
GCinSC2 is offline   Reply With Quote
Old 02-21-2023, 09:59 AM   #6
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
How much time are we talking between cycles?
1st issue (dirty sail switch) caused mine to ignite and run long enough to kick out warmish air. It would then shut off within 3 or 4 minutes, then attempt the entire cycle again.
2nd issue (bad igniter)...1 year later: furnace would ignite, run for 15-20 minutes, turn off before reaching temp, then never re-ignite.
- Stewart
s1000pre is offline   Reply With Quote
Old 02-21-2023, 11:13 AM   #7
DFW , Texas
Gary
It's blowing hot air when it's on. The unit is under the couch on our floorplan. Is the best way to access it to look at the control board removing the couch or can it be accessed from the exterior door? The couch access panels don't allow the furnace cover to be removed
No issues with the stove top or water heater
Old 02-21-2023, 11:15 AM   #8
DFW , Texas
It seems variable, but maybe 10-20 seconds between cycles. It's enough to keep the temperature where I set it in the RV
Old 02-21-2023, 11:31 AM   #9
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Access to the board should be from the exterior. A blinking led will be the error code. 1, 2 or 3 blinks before it repeats. I had an problem where it would cycle on ignite and then shut the gas off, then do it again and shut down with 3 blinks on the board. The furnace worked fine (sometimes), but never worked correctly on a cold wet day. The problem was the ignitor was broken and shorting out to the trailer frame (ground).
Richard
Old 02-21-2023, 12:26 PM   #10
DFW , Texas
Problem solved - sail switch was clogged with cat hair. It was evident after pulling the door off the exterior
Old 02-21-2023, 01:33 PM   #11
GCinSC2's Avatar
We’ll done and thanks for reporting a solution. That helps the next member that finds this thread.
2021 Furnace cycling on and off every 30 seconds s1000pre Furnaces, Heaters, Fireplaces & Air Conditioning 13 01-08-2022 09:01 PM
Need help with furnace short cycling 92landyacht Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-13-2012 10:18 PM
furnace on/off cycling goransons Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-27-2008 07:56 PM
Furnace Thermostat cycling Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-03-2008 09:47 AM
furnace fast cycling - thermostat adjustment emanon25 Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-28-2004 10:06 PM
