Old 01-16-2022, 10:29 AM   #1
2016 27' Flying Cloud
2016 Interstate Lounge Ext
San diego , California
Furnace and blower not working
I have a 2016 27’ Flying Cloud signature that I just bought. The furnace and blower are not working. Does anyone have any suggestions on how I can troubleshoot.
Rstellers is offline   Reply With Quote
Old 01-16-2022, 10:39 AM   #2
2020 19' Caravel
Ammon , Idaho
I would start by verifying power is available.
Is the thermostat working/in the correct mode?
Find the manual and check voltage.
Does the thermostat start the AC unit?
OutdoorIdaho is offline   Reply With Quote
Old 01-16-2022, 10:46 AM   #3
Thermostat is working. Voltage is at 12.5. I’ll check the AC and let you know.
Old 01-16-2022, 02:11 PM   #4
AC is working. I’ll check the voltage with a multi meter at the furnace panel. Checked all the DC circuits and they are good.
Let me know if you have any other thoughts.
Old 01-16-2022, 02:20 PM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Rstellers,
A go to resource for me anyway the document library at My RV Works has several service manuals for Atwood furnaces. https://myrvworks.com/wp-content/upl...ting-Guide.pdf
Darren at My RV works has complied a gold mine of manuals.
The furnace has a sequence of events to start it up and they are frequently very diagnosable just by reviewing against what step does the furnace stop at or the sound it makes etc.
If you can post the model info that can help a bit too. And have you found the CHECK light on the board yet?
Keep the info coming and take a look at those service manuals and download.
Does the stove light up?
Gary
GCinSC2 is offline   Reply With Quote
Old 01-16-2022, 02:45 PM   #6
Awesome. I’ll check the manual and post the model asap.
Yes the stove does work and I lit it to bleed any air from the line.
I don’t hear any sounds at all, no ignition or blower whatsoever, so I think it may be electrical.
Old 01-16-2022, 07:38 PM   #7
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
Do you have a manual thermostat on this? If so, have you checked the slightly hidden on/off switch tucked away on it? Confounded me for a while till I discovered that.
Richard
11018
richard5933 is offline   Reply With Quote
Old 01-17-2022, 09:30 AM   #8
2017 27' International
Antes Fort , Pennsylvania
I've been fooled a few times by a working furnace because the interior temperature was already what I wanted with the furnace on. Duh! Also, it can take almost a minute sometimes for the furnace to start. Don't know why but it does that.
alphamale49 is offline   Reply With Quote
Old 01-17-2022, 09:50 AM   #9
CruizinDux's Avatar
Washington , Missouri
It's a long shot but check the thermostat manual for a hard re-reboot.
I've had this solve a strange idiosyncrasy in mine. After not returning the fan speed to auto form a temp setting on low, my AC would turn on a send cold air into the trailer simultaneously with the intended propane furnace firing. Returning the fan speed back to auto did not solve the dual firing, but the hard boot of the stat did. Go figure
WashMoBob
CruizinDux is offline   Reply With Quote
Old 01-17-2022, 07:12 PM   #10
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
You need to answer a few questions:
Does anything happen when you turn on the furnace with temp set above the inside of the trailer temp? Could be a bad thermostat.
Does the furnace fan start then shutdown? Faulty sail switch.
Is your house voltage above 10.5 volts? I takes more voltage to open the gas valve.
Do you have propane and is it on? Will a stove burner light?
Is the switch under the outside cover on? It is a simple on-off switch.
If all the above are OK, then I would suspect tha circuit board is faulty.
you might consider calling a mobile tech that has experience with your heater brand.
guskmg
Old 01-17-2022, 07:56 PM   #11
CruizinDux's Avatar
Great advice from guskmg.
Here are a couple of sail switch....error light threads
https://www.airforums.com/forums/f28...se-183642.html
https://www.airforums.com/forums/f54...127845-82.html
Post 1577 & 1623
Good luck
WashMoBob
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 5 01-06-2020 11:25 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Dometic heater zone 2 not working on furnace, not hot on HP sfgirl General Repair Forum 13 11-06-2015 01:21 PM
Burner and Blower Won't Start For Furnace heyhello Furnaces, Heaters, Fireplaces & Air Conditioning 14 05-31-2015 04:59 PM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
