Old 09-29-2020, 08:01 PM   #1
2019 27' Globetrotter
Missouri Valley , Iowa
Front Panel Skin Cracking
At our recent Rally, a couple of members mentioned cracks in the skin in the front panel behind the propane tanks. They said the storage door frame in this panel stresses the skin and then it cracks. It begins with a "dimple" at the lower corners of the storage door and then the crack appears in the dimple area. The storage door frame itself has cracked on some units. My 2019 27' Globetrotter has such dimples at both lower corners of this storage door. Has anyone had experience with this ??
Dan
Farmer Dan is offline   Reply With Quote
Old 09-29-2020, 08:23 PM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
You should still be under warranty, what does your dealer or JC say about this?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 09-29-2020, 08:50 PM   #3
I haven't talked to them yet. Just seeing if this a potential problem for me. I believe that I saw you had a problem with your bathroom door handle ?? We have the exact same problem. I will be in touch with the factory for a new handle.
Dan
Old 09-29-2020, 09:24 PM   #4
rperrym's Avatar
2017 27' Tommy Bahama
2016 30' Flying Cloud
2014 27' FB Eddie Bauer
Hot Springs Village , Arkansas
Mine has a dimple, but it is where the rivet is located. So far, no cracks after almost 4 years.
2017 27 Tommy Bahama
2020 2500 GMC Duramax
rperrym is offline   Reply With Quote
Old 09-29-2020, 09:29 PM   #5
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
We are talking about that on our 2020 right now. We sent pictures to Jackson Center, they confirmed what it was (at this point we have small creases) and was urged to get it in to have the front hold downs redone. Check out the thread. Sounds like yours has progressed.
https://www.airforums.com/forums/f54...-199643-2.html
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 09-29-2020, 09:50 PM   #6
2018 30' Classic
Dan
Oh yeah, we are three years into our classic full time living. A few things have needed repair but living in it full time, Itís all maintenance as far as Iím concerned. Would have spent much more on a house.
Door knob is easy to replace on your own with a basic screw driver as well. We got used to turning the handle up to open it which I believe is recommended in general and we still turn it up instead of pushing down.
BigSxyWhtGuy
Old 09-30-2020, 07:17 AM   #7
The link and pics you sent show exactly what we have. Thanks for the info !!
Dan
Old 10-01-2020, 12:20 AM   #8
Merriam , KS
Sounds like the beginnings of front end separation. Especially of JC mentioned the hold downs needing redone. I'd ask for a hold down plate like they did in the old days.
DougC27 is offline   Reply With Quote
Up on the roof and noticed cracking sealant Getahobby Roof 5 08-04-2012 07:54 AM
Trouble with Sansui TV case cracking russ240 Sprinter and B-van Forum 6 08-03-2012 08:13 AM
Tires Cracking - Any Suggestions NavyDavesCvl Tires 10 03-28-2010 02:43 PM
Cracking end cap 76 Tradewind Siamese66 General Interior Topics 2 10-19-2006 05:27 AM
Rear Bath Upper Wall Cracking w5wi General Interior Topics 0 07-20-2003 08:13 AM
