I put some freshwater (25%) in my tank a couple of weeks ago since the campground we were staying at was having cold weather and shut off the water. The next day, after it warmed up I opened the valve to let the water drain. I am still having water dripping out almost 2 weeks later. Is there any other reason why this tank would still have water dripping out?
You didn't say what the low temps were or how long they lasted. You also didn't say what the current temps are since the cold snap ended. If water froze solid in the tank, it will take a while for all of it to melt and drain. It sounds like you had a block of ice in the tank and it's slowly melting. How fast it melts depends on the current temps in your location.
