02-05-2022, 08:12 AM
2018 30' Classic
Fort Collins
Freshwater tank filling on it's own?
We have a 2018 Classic and are parked with shore water on.
When we left home the freshwater tank was at 35%.
Yesterday (after 3 weeks parked) i noticed the tank
was at 90%? Not sure how this could happen?
Any suggestions?
Monty
02-05-2022, 08:16 AM
2019 30' International
Pennsylvania
, Pennsylvania
Water pressure from the city water hookup pushes past the on board pump and slowly fills up the on board freshwater tank. There could be a weak seal in the pump, or a piece of grit stuck in the pump seal that allows the water to seep backwards past the pump and in to the freshwater tank.
First thing I'd recommend is unhook city water inlet and use the on board pump for a day or two. Some times this will rectify the situation.
Then hook up the city water again in a couple days and monitor the freshwater tank to see if it's been resolved.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
02-05-2022, 08:19 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Both the shore water and the fresh water tank hook to the same pipes in the trailer. There are "back flow" valves that stop the water pump from pushing water out the shore water input. There also is a valve that should prevent the shore water from backing up into the fresh water tank.
Both of these valves can get crud in them. Both can leak as a result. The valve on the shore water input can easily have freeze damage. In your case, the quick fix is to run the water pump for a bit. This usually clears any crud. It might be worthwhile to clear the strainer before you do this.
02-06-2022, 07:13 AM
2018 30' Classic
Fort Collins
Two great answers! Thanks so much I will
Give it a try!
Monty
02-06-2022, 10:06 AM
1974 27' Overlander
2015 28' International
Little Rock
, Arkansas
I'm guessing the strainer is on the water pump. How do you get to it?
02-06-2022, 11:23 AM
2015 30' Classic
Topsham
, Maine
We snow bird in Tucson and the water has its share of mineral deposits. Going from pump operation to shore and back occasionally resulted in the tank filling at random times. We leave the fill door open just in case. A couple of times the fresh water tank has overflowed through the vent.
We do cycle the pump a few times to clear the check valve seat on the pump and that seems to work. For a while.
If we have no need for onboard water we can leave the tank drain open. Either way works to prevent tank over pressurization and damage.
02-06-2022, 11:51 AM
2015 25' FB Flying Cloud
Barnstable
, Massachusetts
Just a little suggestion beyond all the above. I wouldn’t leave the city water on when not occupying the trailer. A pipe could easily burst, and you would be in for a very bad day when you returned. Just saying!
02-06-2022, 03:05 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Ditto #7. Also , use a Camco Blue filter on the city water line and also when you manually fill the fresh water tank. I have done that on two trailers with no back fill problems for 30 years.
guskmg
02-07-2022, 07:51 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
When you dive in to winterize your trailer, you will find the water pump mounted in some odd place. Attached to the input to the pump / part of the pump is a little strainer gizmo. You dump them once a year as part of the winterize process. ... hmmm .... don't winterize you say? Still need to clear the strainer once a year.
02-07-2022, 09:36 AM
2004 30' Classic Slideout
Fenton
, Missouri
When our trailer was brand new we had this happen to us. Dealer said it was a bad check valve in the pump which allowed city water to flow into the holding tank. The pump was replaced under warranty and all was well.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
02-08-2022, 05:44 PM
K4TCJ
2009 27' FB Flying Cloud
Crestview
Mine did that when hooked to city water. It was the check valve mounted on the very front of the pump. A very easy repair.
02-08-2022, 05:55 PM
2018 28' Flying Cloud
Chapin
, South Carolina
Our did same when new. Running pump corrected for a couple of years. Last fall it started slowly leaking by again. Bought just the check valve and replaced. No problem since. I remember the valve being just over $20. We do try to remember to turn city water off when leaving for any extended period.
02-13-2022, 05:24 PM
2016 25' Flying Cloud
Houston
The pump has a check valve built in. It is common that they fail or leak allowing city water to fill the fresh tank. Sometimes you can stop a leak by running pump to clear crud that causes a leak in check valve. I kept having the problem and simply installed an additional brass check valve. It’s a cheap fix, parts available at hardware or plumbing store.
02-14-2022, 07:09 AM
2006 16' International CCD
Valparaiso
I had the same problem and needed to replace flap valve on water pump . That fixed it.
02-14-2022, 10:00 AM
2014 23' International
Hurst
You can just buy one of these:
https://www.amazon.com/Camco-23303-B...%2C158&sr=8-42
... and put it on the inlet side of the pump. Fixed forever and it took ten minutes (assuming you can find the pump!).
02-14-2022, 10:46 AM
New Hyde Park
, New York
Great suggestion, Rob. Does backflow valve install take place before the strainer or after? Does it matter? Thanks
Bruce
2021 Ram 1500 Laramie - 5.7L Hemi eTORQUE
Airstream Club International #2600
I’d rather be camping is an understatement!
02-14-2022, 02:52 PM
Hurst
Doesn't matter a bit... just put it wherever it's easier to get to. I installed one of these even with NO issue with the pump's built-in check valve. I like to proactively do whatever I can to prevent bad stuff - or even nuisance stuff - from happening.
Rob
02-14-2022, 03:09 PM
Hurst
Rob
04-26-2023, 11:24 PM
Seattle
Originally Posted by RFP
Digging up an old thread here.
We found our fresh tank filling while on city water and I'd like to install the check valve.
I see the shurflo pump in our AS has NPSM threads on the inlet and outlet. This valve is NPT threads.
Have you had any problems with the check valve threading onto the water pump?
04-27-2023, 08:01 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
We never have the "shore" water hooked up, consequently the pump one way has never failed.
POI we fill the tank when needed without worry.
This is the reason...at 3am it poofed, cross threaded at the factory, repaired on the road with MarineTex 13 yrs ago.
