Old 05-31-2017, 08:25 AM   #1
2011 25' FB Flying Cloud
CLERMONT , Florida
Fresh water leak
Fresh water tank in 2011 flying cloud has a pin hole leak. How do I repair it ?
Jamescaldwel is offline   Reply With Quote
Old 05-31-2017, 11:40 AM   #2
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
First question might be: How did it get the pinhole leak? If it's road debris that's one thing. If it is something like a screw through the tank (I've had that problem, but not on an Airstream) there may be other staples / screws .... Fixing them one at a time is not fun. I've been there and done that.
Old 05-31-2017, 06:31 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Greetings JamesCaldwel: Welcome to the Airstream Forums. I have found hundreds of folks that have had Airstream problems like mine and offered helpful advice.
You have a newer trailer. It is highly unusual for it to develop a "pinhole" leak. I worked in a rotomolding factory where every tank was pressure tested for leaks. This is a common practice, and very effective. I doubt it was leaking from day one.
So tell us more about this pinhole leak. Maybe it was punctured with a sharp object like uncle_bob suggests. Your tank is protected from road debris by the tank pan underneath. The tank pan likely hold up the fresh water tank. Have you visually watched water dripping from the side or bottom of the tank? Difficult to do I imagine.
My 86 (ya, completely different) had a fresh water plumbing leak below the floor, and above the tank. Oh great! This leak appeared as a fresh water tank leak. I had to drop the tank to fix the plumbing leak. The 30 year old tank was in good shape and will likely last another 30 years. See photo.
Your fresh water tank is likely made from polyethylene material. This is a thermoplastic material. It is weldable. It is possible to heat the pinhole to near melting, add a bit of polyethylene, and the tank is repaired. Adhesives are less effective, but there are some out there that people use.
David
Name:	1610 Fresh Tank and Pan (Small).JPG
ID:	286653   Click image for larger version
Name:	1610 Fresh Tank Down 1 (Small).JPG
Old 05-31-2017, 06:56 PM   #4
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
If you can get at the hole, take a flat screwdriver and heat it red hot and just carefully move the plastic around the hole till it's filled in.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 06-01-2017, 08:36 AM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
That will work shacksman. I wish I had thought of it. I have read some folks use a soldering iron to do the same thing.
David
Old 06-01-2017, 10:29 AM   #6
2008 22' Safari
Are you certain it's a pin-hole leak in a tank..??? and not a loose clamp on a hose at the drain....? or some other fitting issue?
Exactly how does the leak manifest itself?
(I'm not saying it's improbable.... with the number of rivet-tails, loose screws, and metal-filings and cuttings found beneath floors, inside cabinets, behind walls.... a tank rubbing/vibrating against such trash can eventually penetrate the tank.... something that Airstream should have to be held accountable-for despite the expired warranty-period, in my opinion since that would be a clear manufacturing defect.)
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 31 05-15-2022 10:25 PM
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 26 04-24-2021 05:23 AM
City Water Hooked Up Making Fresh Water Tank Leak/Overflow??? Wgbarrbevco Fresh Water Systems 18 11-24-2017 03:45 AM
How long fresh water stays fresh? cellarrat Boondocking 28 02-07-2016 01:39 PM
Can't find water leak - near fresh water tank. Loren Fresh Water Systems 16 01-01-2006 05:40 PM
