Old 08-05-2018, 09:53 AM   #1
TetonStreamer
Teton Stream's Avatar
2017 23' Flying Cloud
Washington , DC
Floor Template for floor covering
Does anyone know if there are floor layout templates available for currently produced Airstreams? Specifically I am interested in installing wall to wall floor covering in a 2017 23FB and did not want to have to reinvent the wheel.
Teton Streamer - in The Toaster
Wilson, WY 83014
Teton Stream is offline   Reply With Quote
Old 08-05-2018, 10:57 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Go to a Big Box Store. They have a template creator kit. You lay down a construction paper that is a 1/2 in short at all edges. Then with the supplied plastic wheel you trace the perimeter on the paper 1 in smaller than actual. Lay that in your material and cut to fit.
Works great fro rugs and depending on your attention to detail hard flooring also.
2004 Excursion 4x4
Old 08-05-2018, 11:07 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I doubt it, the flooring is installed before the interior.... AND the interior of two "identical" Airstreams might easily be off by a quarter of an inch. They're built by hand after all. If you do get one, test fit it first!!
Check with a flooring store, it has been several years, but it used to be you could get heavy duty grid paper designed for this chore... now? Someone probably has a laser that can shoot the layout and cut the tiles, boards, or vinyl sheet goods for you.
Yesterday's AVANT is today's PASSE'
shell replacement without a floor template FlyingCloud3 Repairing/Replacing Floor &/or Frame 5 11-14-2015 05:00 AM
Black water Tank as floor template teilhet Repairing/Replacing Floor &/or Frame 2 07-15-2015 01:04 PM
Creating a replacement floor template from a sketchy predecessor... KCN Repairing/Replacing Floor &/or Frame 5 08-09-2012 09:10 PM
Help --need a '67 floor template pinkflamingoes Repairing/Replacing Floor &/or Frame 17 08-01-2006 02:11 AM
When lacking a floor to make a template... JrnymnJay Repairing/Replacing Floor &/or Frame 6 11-30-2002 06:28 PM
