I have a '66 17ft Airstream Caravel and I'm trying to replace the thermal coupler. If you have a good source for oven parts please pass it along to me...Andy
1963 28' Ambassador
Northern VT
, Vermont
I know it sounds to easy, but. I've changed them in dozens of gas appliances. IF it is just the thermocoupler that seperates from the pilot all you need is one with the proper end that inserts in the gas control valve & reasonably close wire length. Remove the old one take it to a hardware store to compare ends. If they don't have it they can point you in the right direction. Usually< $20.00.
