Old 01-20-2006, 04:06 PM   #1
Alumaholic's Avatar
2019 27' Flying Cloud
Albuquerque , New Mexico
Images: 36
Fixing Foggy Fenestration
Greetings Fellow Alumaholics.
My '76 Sovereign came with dual pane (or should that be pain), tinted windows. After 30 years, the film between the glass of all six operable windows has bubbled and turned into an ugly mess.
I have read all the posts on fixing the vista view windows. Has anyone out there successfully fixed the larger windows using the "break the inside pane technique?"
Are there other techniques you would like to recommend?
Ken
Albuquerque
Alumaholic is offline   Reply With Quote
Old 01-20-2006, 06:21 PM   #2
Alumaholic's Avatar
Images: 36
Please Help, Must Fix Windows
Someone out there has dealt with this. I just know you have.
Old 01-20-2006, 07:06 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Ken,
FWIW I definitely think they are a pain. I did the Vista View thing, but I have never even seen a thermopane window on an Airstream. I do know they exist. Can you post a couple of pictures of the inside frame and the outside frame, it might give us some insight...I know with the Vista View you can't completely remove the glass from the frame on the 75 on. I also know that if you screw up and break BOTH panes it is PAIN...$250+ and 57 rivets worth
Aaron
WBCCI #XXXX AIR #2495
Old 01-20-2006, 08:53 PM   #4
Alumaholic's Avatar
Images: 36
Thanks Aaron. I will take pictures tomorrow and post them.
Ken
Old 01-21-2006, 04:10 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I have done my Vista's in the Trade Wind, check out my page if you's like?
http://www.balrgn.com/Airstream/airs...oject_2004.htm
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-21-2006, 04:47 AM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Ken,
Just a heads up...balgrn has the old style vista views...it doesn't work that way with the newer ones. I have pictures of the process somewhere...
Aaron
Old 01-21-2006, 08:46 AM   #7
Alumaholic's Avatar
Images: 36
Vista Views OK; Windows Need Help
Thanks balgrn and Aaron,
Some previous owner has done the job on the upper Vista View windows, and they look great. Its the double pane, hinge at the top, operable windows that have bubbled and become translucent, as well as the lower Vista View windows below them.
Ken
#8654
Albuquerque
Old 01-21-2006, 05:26 PM   #8
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Me, too. And (gasp!) the center seal of my curbside front picture window is sagging now.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 01-23-2006, 01:31 PM   #9
Alumaholic's Avatar
Images: 36
Fixing Foggy Fenestration; Pictures
Okay fellas, here's what I am up against. This is the window above the bunk on the roadside.
Next post will show window at dining table on roadside.
Ken
#8654
Albuquerque
Old 01-23-2006, 01:34 PM   #10
Alumaholic's Avatar
Images: 36
Fixing Foggy Fenestration; Another Picture
Here's a shot of the window above dining table on roadside
Ken
#8654
Albuquerque
Old 01-23-2006, 02:26 PM   #11
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Attachment 17885
Ken
#8654
Albuquerque
Hmmm, looks like you should be able to use a razor to scrape it off, if you are concerened about scratching, VintageTrailor has some cool ceramic blades for cheap money, do a key word search on his site for razor.
www.balrgn.com
Old 01-23-2006, 02:51 PM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Unfortunately he has the double pained windows...the peeling crap is in between the glass like a vista view....
Aaron
Old 01-23-2006, 03:06 PM   #13
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Aaron
Oh Bummer!
www.balrgn.com
Old 01-23-2006, 05:05 PM   #14
Alumaholic's Avatar
Images: 36
Balgrn,
Thanks for the tip about the scraper. It's on order!
But as Aaron points out, the goop is between the panes on the doubl pane glass.
Thins I can break the inner pane like you did on the Vista Views?
Ken
Old 01-23-2006, 05:07 PM   #15
1975 29' Ambassador
Reno , Nevada
My 75 has bubbles in the windows, too. The only way I have seen to fix them is to replace the glass, which means, essentially, replacing the windows.
this is an ouch as they have Airstream quality pricing.
Old 01-23-2006, 05:27 PM   #16
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Balgrn,
Ken
I lucked out, did not need to break anything. Thre must be away to disassemble. I'll look at a friends 31'er. Will be a week or so, goin south on vacation!
www.balrgn.com
Old 01-23-2006, 06:10 PM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
75 was the split year on the Vista Views after a certain point they went to the ones like I have, where you have to break the inner pane to get it cleaned out. I did that on mine, but slipped up with the punch on one of mine and had to replace it. Cost was around $250 57 rivets and then after a good hard rain it leaks...between the glass and the frame! And I am not going to take it back out! So I cut the seal back and resealed it with Vulkem, needless to say Airstream's QC was not good on that unit.
Klevan, can you get some close up pictures of the inside near the frame? I suspect they are made like the corner windows on the front of mine. I have heard of people breaking the inner panes on those but I have not seen it done. I did notice that yours has the holes drilled in the outside to help drain the condensation from between the glass.
Aaron
Old 01-23-2006, 06:54 PM   #18
1975 29' Ambassador
Reno , Nevada
I have a good example of the 75 change. A friend has a 31' built in the same month and factory as my 29' but he has the easy to fix vista views. I don't.
Of course, pulling the inside skin to straighten ribs (anyone have a spare rib? we need one or two - and how do you get one of those to Reno?) helps with access.
Old 01-23-2006, 07:32 PM   #19
Alumaholic's Avatar
Images: 36
Very observant, Aaron. Yes, some PO has drilled from the outside to drain condensation. The double paned windows are now condensation free ; however, the UV protectant film has bubbled .
The advise is good. I'll take inside shots as you request.
Ken
Old 01-23-2006, 08:32 PM   #20
1979 25' Tradewind
Takoma Park , Maryland
'79 Trade Wind with Vista View Problems
Hi, I've got a '79 Trade Wind with Vista View bubbles. Am I going to be able to fix them like Balrgn or are they different on my model. They look like double pane (pain) to me.
Thanks, Wendy
WendyW is offline   Reply With Quote
fixing the antenna barbwire All Argosy Trailers 16 05-29-2005 01:30 PM
Fixing the Floor 61BambiCanada Repairing/Replacing Floor &/or Frame 6 01-06-2004 09:21 AM
Foggy Memory Ln. Rusty Bucket Our Community 1 12-29-2002 07:07 PM
Fixing a scratch on a brushed finish? acwdgw Cleaning, Stripping & Polishing 3 10-22-2002 01:27 PM
Fixing things-'RV Repair and Maintenance Manual Joan D'Andrea Our Community 6 09-19-2002 04:49 PM
