Old 02-13-2016, 07:33 AM   #1
2014 28' International
undisclosed , Idaho
First trip no heat or gas at stove?
We are in cold weather without furnace or gas at stove. Left dealer yesterday with all systems go in our 2014 international signature.
What should we check first?
Thank you!
jeffryorange is offline   Reply With Quote
Old 02-13-2016, 07:34 AM   #2
Mantua , Ohio
Propane tanks on?
xrvr is offline   Reply With Quote
Old 02-13-2016, 07:34 AM   #3
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
is the hot water heater working?
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 02-13-2016, 07:38 AM   #4
Sag Harbor , New York
Dealer probably turned propane tanks off for your safety. Turn tanks on and try one gas burner on the range, and report back.
Old 02-13-2016, 08:01 AM   #5
new air
Bloomington , Minnesota
Make sure you have propane make sure your spark igniter is working (battery or electric operated ) then propane lines can get cold and propane lines freeze kind of like a cigarette lighter course I'm in Minnesota that's how It works when it's really cold
pm9617 is offline   Reply With Quote
Old 02-13-2016, 08:20 AM   #6
new air
Does anyone know if that's a propane line that hang exposed under the trailer or a water line if so what's the reason something that important would be exposed
Old 02-13-2016, 08:39 AM   #7
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Better exposed than in the trailer. Should it develop a leak the gas disperses. Enclose and should it develop a leak, kaboom 'bye 'bye trailer.
Gearheart is offline   Reply With Quote
Old 02-13-2016, 08:47 AM   #8
new air
Okay yeah that makes sense
Old 02-13-2016, 10:20 AM   #9
Thank you!
Any luck with the suggestions so far?
Peter
Old 02-13-2016, 10:46 AM   #10
The Ice Man's Avatar
2011 27 FB International
Tucson , Arizona
Likely you haven't purged air from the propane lines.
Insure that the propane valves are open and the indicator shows GREEN, meaning the presence of propane pressure in the system. Then go into the trailer and turn on a burner on the stove using either the igniter or a butane lighter until the burner lights. This indicates that air has been purged from the lines.
Next, cycle the water heater until it lights - should only take one or two times. The heater should then light on the first or second attempt.
IIRC, the propane line is outside the trailer by code.
Let us know if you're successful.
The Ice Man is offline   Reply With Quote
Old 02-13-2016, 10:49 AM   #11
Hbjason's Avatar
2015 20' Flying Cloud
Huntington beach , CALIFORNIA
I had same problem my first trip. I turned on water heater in bathroom. And it purged air out of line hope this helps
Hbjason is offline   Reply With Quote
Old 02-13-2016, 11:35 AM   #12
dames7's Avatar
2015 25' Flying Cloud
GILBERT , Arizona
First time out. It's most likely air in the lines.
Turn stove on a bleed out the line, it could take a minute or so, just one burner.
Make sure you open your door while doing this.
David & Nancy Ames
WBCCI # 9403 -- AIR # 95597
2015 FC 25' RB
2013 Chevy Tahoe LTZ
dames7 is offline   Reply With Quote
Old 02-13-2016, 04:33 PM   #13
SuperTrouper's Avatar
2008 27' International FB
Petaluma , California
Yep. First lesson I got when I met someone in the storage facility when first parking the trailer. He came over for a look at the AS and then said "after a long spell in storage you need to run the stovetop burners a bit to get "good gas" in the lines". I do this every time I take it out. Run the burners and the furnace for a bit and then light the fridge and hot water. If you don't purge the lines all the appliances ignition cycles will time out before good gas gets to their burners. If the tanks are really topped off, sometimes you need to close them and reopen them slowly to reset the safety flow limiter in the tank. As another poster mentioned, keep the door open and the igniter or match continuous until you get flame at the burners.
Looking for adventure in whatever comes our way.
- Brad
SuperTrouper is offline   Reply With Quote
Old 02-14-2016, 08:08 AM   #14
undisclosed , Idaho
No propane on first trip out
Thanks to all you ASers out there who responded to our problem of no propane on our first trip out. After trying many of your suggestions to no avail, we decided to go back to the AS dealer (1.5 hours out of our way). They ended up installing a new regulator so turns out nothing we could have done. However, if this were to happen again does anyone have a short-term "gerry-rig" solution?Thanks
Old 02-14-2016, 08:54 AM   #15
2016 27' International
Columbia , South Carolina
We had a similar problem years ago with one of our former units, and it turned out the regular was mounted crooked. Repair man came out, poped the bottom screw out, leveled it up, put the screw back in, and we were back in bussiness.
dazwelding is offline   Reply With Quote
Old 02-14-2016, 10:23 AM   #16
There is no shortcut to bypass a bad regulator IMO. I thought the dealer sent you off with all systems working at the get go? A small plug in electric heater or two are good to have on hand for propane emergencies, but obviously you need electric.
Glad you are on the road again!
Peter
Old 02-14-2016, 10:59 AM   #17
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
You can buy a cheap regulator at WalMart or Home Depot to get yourself out of a tight spot should this happen again.
Brevi tempore!
J. Morgan is offline   Reply With Quote
Old 02-14-2016, 09:49 PM   #18
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Suggest that you have a propane pressure gauge (manometer) installed. Mine is installed using a "T" in the gas line to the refrigerator. That way you can tell if the regulator needs adjusting.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
First AS - First Trip PharmGeek On The Road... 70 12-05-2013 03:25 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
First Trailer, First Trip Tin Diesel On The Road... 15 02-01-2006 12:23 AM
First Big Trip, First Time Float Tubers :eek: Rhodie On The Road... 14 08-11-2005 02:18 AM
