Old 06-10-2021, 03:19 PM   #1
2006 28' Safari SE
Raleigh , North Carolina
FC Bunk - Body splitting around door
How big a deal is this? Anyone have experience repairing this? Im looking at a flying cloud 30 bunk with this damage. Thanks!
Dmccloy is offline   Reply With Quote
Old 06-10-2021, 03:31 PM   #2
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
You might have forgotten the photo.
- Stewart
s1000pre is offline   Reply With Quote
Old 06-10-2021, 03:50 PM   #3
2006 28' Safari SE
Sorry, think they are up there now
Old 06-10-2021, 04:32 PM   #4
s1000pre's Avatar
Inspect the front of the AS. It could be caused by constant slamming of the door, or stiff weight distribution bars behind a vehicle with stiff suspension. Look for creases up front, if there are no creases...then I would probably run with the slamming door theory.
- Stewart
Old 06-11-2021, 09:14 AM   #5
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
No photo's I can find ....
Old 06-11-2021, 11:16 AM   #6
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
Body splitting? Do you mean splitting at a 45 degree angle from the upper forward corner of the the door frame on the outside? If so, there are a lot of other aluminum trailers that have done done that and it is caused by the shell flexing when going over irregular surfaces, thust wisting the shell. Because it will happen again if you replace the skin, I would make a neat doubler patch and got from there. You could also have a cracked frame. There are a lot of. trailer out there with unknown frame cracks. Airstream may already have fix for that. I would call them and see what they recommend. I have popped a rivet there, but the replacement has held.
guskmg
Old 06-11-2021, 11:35 AM   #7
kathfred's Avatar
2012 25' Flying Cloud
2001 19' Bambi
Fresno , California
Still no photos.
kathfred is offline   Reply With Quote
Old 06-12-2021, 06:20 AM   #8
2006 28' Safari SE
If I view this thread on a PC, I see the photos. If I view them on a phone I don't. i just tried making sure its public, my url is google photos. Anyone got any ideas? I'm going try posting again here...
Old 06-12-2021, 06:34 AM   #9
DaveP's Avatar
2004 28' Classic
Monument , Colorado
This looks like the front of the trailer next to the rock guard and above the trailer frame. Is that the correct location?
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 06-12-2021, 06:43 PM   #10
DaveP's Avatar
2004 28' Classic
Monument , Colorado
If my previous post is correct, I have some input for you. If not, I don't.
DaveP
2023 Ram 3500 4x4
Old 06-12-2021, 07:21 PM   #11
2018 30' Flying Cloud
Huntsville , Alabama
This looks like the front end separation. I had a crack repaired at at the factory last year. Would have to remove the front panel and replace it. Is the front trim band loose also?
143pm is offline   Reply With Quote
Old 06-12-2021, 07:31 PM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Run away….leaverite
Old 06-12-2021, 07:58 PM   #13
This can be repaired as good as new. My understanding is this could be an issue on any 30 fbb. They can weld additional tabs to the frame when the front panel is replaced. I would get a quote on the repair before considering purchase.
Old 06-13-2021, 08:50 AM   #14
Half a Rivet Short
2022 Interstate 24X
Hi
This is not something I would ignore. You either repair it or you don't buy the trailer. It's not going to be a cheap fix, but it also is not an impossible thing to do. Like any frame related issue, you really will not know how extensive / expensive it is until it's all back together.
With cracks both above and below the door, you will have some work to do .....
Old 06-14-2021, 06:12 AM   #15
1988 34' Excella
Stanardsville , Virginia
Can only see 1 photo the others are not displaying. Are there any wrinkles in the surrounding panels?
madpiper is offline   Reply With Quote
Old 06-15-2021, 07:52 AM   #16
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Is that all filaform around the awning arm that meets the aluminum?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 06-15-2021, 07:53 AM   #17
Half a Rivet Short
2022 Interstate 24X
Hi
..... are there any signs of trouble on the other side of the trailer? (wrinkles ...)
Old 06-16-2021, 09:12 AM   #18
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
That looks like a stress crack which has happened to me on my first trailer. Turns out my F350 suspension and 1200# bars equalizer bars were way too stiff for the trailer, a 27 FB. The too stiff system was beating the trailer to death. I changed to 600# bars and life was better for the trailer.
So what is your tow vehicle and the rating and brand of your WD system?
The ability to follow instructions is highly underrated.
Always be wary of stupid people in large numbers.
hhendrix is offline   Reply With Quote
Old 06-16-2021, 10:47 AM   #19
2008 27' International FB
Oklahoma City , Oklahoma
Front end separation
I had this problem. Front end separation. I think it is pretty common with the trailers with front storage box. The front of the trailer is not attached good enough to the frame. I had Colin Hyde in NY fix mine. They go in and weld additional attachments. Quite a bit of work but it seems to have fixed it. Mine started with a crack on one side and then the other and finally rivets around the storage box started popping off. I want to say the fix was about $2400. I would say a patch will not fix it.
Americal is offline   Reply With Quote
Frame rail is splitting CA_Tallguy Repairing/Replacing Floor &/or Frame 17 02-09-2014 10:00 PM
Whoo boy... splitting in the copper lines SUEHOWIE LP Gas, Piping, Tanks & Regulators 5 03-02-2009 04:32 AM
splitting off a/c or microwave 1994 34' Excella richinny Electrical - Systems, Generators, Batteries & Solar 6 08-04-2007 09:46 PM
Electrical Help - Splitting a receptacle COArgosy78 Electrical - Systems, Generators, Batteries & Solar 4 07-03-2005 03:57 PM
