Old 12-16-2019, 12:25 PM   #1
2016 27' International
Santa Rosa Beach , Florida
Faulty propane leak detector (?)
I have my AS housed in a detached garage with hookups. On 3 separate occasions I have found the light red and the alarm going off whenI go out to the AS in the morning. The propane is completely turned off to the unit. I bought a back up plug in detector to also monitor for leaks. It has yet to detect the presence of any propane inside. I reset the detector which blinks red a few times and goes back to green light. 2016 Signature 27FBQ. Any thoughts?
FL Dawg is offline   Reply With Quote
Old 12-16-2019, 02:24 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
Dust can cause false alarms. Use a vacuum cleaner or canned air to blow out the detector area.
Also, the detectors have a finite life. Yours should still be good but you may be experiencing an "infant mortality" failure.
Al
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 5 08-26-2021 05:17 PM
Propane Detector/Leak jarreau Sprinter and B-van Forum 7 02-03-2016 03:43 PM
Propane Gas Detector Went off Last Week-Turns Out NOT the Propane breezyway Electrical - Systems, Generators, Batteries & Solar 4 08-16-2014 09:56 AM
Propane Leak Detector? Doug C LP Gas, Piping, Tanks & Regulators 46 08-14-2013 07:19 AM
Faulty Floor or Faulty Design? rmax1 Repairing/Replacing Floor &/or Frame 22 05-11-2011 05:38 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
