Old 10-21-2016, 05:51 PM   #1
2017 25' International
Milford , Delaware
Fantastic Vent
Got my fv 7350. When installing, did anyone use the gasket that came with the fan, or just butyl tape, or both?
Also, in the instructions, it refers to a clamp fan - what is that? The instructions are terrible and the company is not open until Monday.
Any help is appreciated.
MikeSandyZ is offline   Reply With Quote
Old 10-21-2016, 06:16 PM   #2
1973 23' Safari
1970 27' Overlander
Boerne , Texas
I had a different model - I think 2250. I did not use the gasket - butyl tape along with Vulkem in the screw holes and along the outside of the flange. Someone had recommended using washers with the screws - this is helpful. I used #8 3/4 inch screws and it worked well. A couple did not seat well, so I went up to #10 on a couple.
Greg1410 is offline   Reply With Quote
Old 10-21-2016, 06:21 PM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
I just bought a new FF. It did not come with a gasket. I used butyl tape under the frame and Dicor self leveling caulk on the frame edge and screw heads.
CRH is offline   Reply With Quote
Old 10-21-2016, 07:19 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If your new fan came with screws to fit a countersink hole in the flange don't use them. Get some stainless steel pan head screws of the same size (#8 I think) and put a SS washer under each. This will spread the clamping force over a much greater area on the flange and this will help keep the flange from cracking at the screw holes. I tossed the gasket and used a thick bead of Vulkem. 7 years-no cracks,no leaks.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 02:01 PM
Vent Covers Over Fantastic Fan flyfisher Roof Vents, Skylights & Fans 14 01-24-2006 04:02 PM
Fantastic Vent R&SZinser Roof Vents, Skylights & Fans 11 11-30-2005 08:56 AM
Fantastic Vent sticking 74Argosy24MH Roof Vents, Skylights & Fans 37 06-09-2005 06:15 AM
Which Fantastic Vent? uwe Roof Vents, Skylights & Fans 9 08-30-2004 10:37 AM
