Old 05-17-2020, 02:53 PM   #1
CVaznis's Avatar
1976 31' Sovereign
Allen , Texas
Fantastic Fan sealer question
It seams that I have a choice when installing my 3 new Fantastic fan vents to either use the gasket or a sealer (I bought the 3M marine sealer) What would you experienced airstreamers recommend?
Christine
CVaznis is offline   Reply With Quote
Old 05-17-2020, 10:31 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I did not use the supplied foam gasket. I used butyl tape to seal the fan housing to the trailer top and then put Dicor self leveling around the frames edge and on the screw heads.
CRH is offline   Reply With Quote
Old 05-18-2020, 06:16 AM   #3
CVaznis's Avatar
1976 31' Sovereign
Allen , Texas
Thank you!
Old 05-18-2020, 06:40 AM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
3m 4200 under the flange and 3m extreme sealing tape over the top edge.
6+ years SFSG....
ID:	368147   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on fire"
Amanamus
Tahawus....🌥
Old 05-18-2020, 09:31 AM   #5
CruizinDux's Avatar
Tracktown USA , Oregon
butyl tape instead of foam gasket and sikaflex. 221 ( i believe) per Lewster's recommendations on the Forums sealants thread. Be careful at the corners and don't overtorque. Both of mine cracked likely at oem install.
CruizinDux is offline   Reply With Quote
Old 05-18-2020, 04:23 PM   #6
CruizinDux's Avatar
I had to go back and confirm which Sikaflex was used...both at diferent times it appears. I had to request the AS dealer, who had never heard of Sikaflex following: White 715 for the 2 FV replacements and White 221 for the Peel n' Seal of the roof seams. They did use the butyl tape as the gasket.
two of Lewster's posts on the Sealants thread.
"Post 21
https://www.airforums.com/forums/f45...ml#post1549683
I use 221 in white for roof seams, 221 grey for windows, doors and general sealing on aluminum and 715, which is a silane terminated polymer (doesn't harden and crack) for major roofing seams and around protrusions like fans, vents, skylights, etc. as it is self leveling."
"Post 100
https://www.airforums.com/forums/f45...ml#post1607610
DON'T apply SikaFlex 221 to anything that you may eventually want to remove, without a replacement going in it's place. It is extremely tenacious and there is no known solvent.. mechanical removal is the only process that works.......and it ain't easy!!!!!"
Old 05-18-2020, 04:49 PM   #7
Lafitte's Avatar
2019 25' Flying Cloud
Bullard , Texas
Eternabond
4" Eternabond
Bob's your Uncle .....
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
Lafitte is offline   Reply With Quote
Fantastic Fan, Dining Room Lights and Bath Fan not working Arbi Electrical - Systems, Generators, Batteries & Solar 19 08-15-2019 08:29 AM
Fantastic fan not so fantastic PeterD General Repair Forum 8 11-16-2015 01:01 PM
Original fan vs fantastic fan KYAirstream Roof Vents, Skylights & Fans 16 08-14-2015 04:51 PM
Maxx Fan Vs. Fantastic Fan Lumatic Roof Vents, Skylights & Fans 19 09-07-2011 07:10 AM
Late 70's light/fan Fantastic Fan installation question tschat Roof Vents, Skylights & Fans 2 07-18-2009 01:30 PM
