Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Clearcoat, Exterior Paint & Trim
Old 01-29-2020, 07:47 PM   #21
2014 27' FB International
Bon Air , Virginia
Funny (strange, not haha), I just replaced some of the chrome stuff on mine this past weekend and feeling pretty stupid for not checking auto parts stores - paid $2 & $3 a foot, respectively, for the 1/2” & 1” of the same stuff at Out of Doors Mart.
Agree that there is nothing to replacing it. Carefully pry and peel old stuff, clean track (how’d all that grime get in there!?), and stick the new stuff in place.
Cheers,
Brenton
Brentone is offline   Reply With Quote
Old 04-02-2023, 12:13 PM   #22
1987 31' Excella
Whitney , Texas
Originally Posted by ROBERT CROSS View Post
Where the plastic extrusion had come off the metal channel, I re-attached with 3m 5200, covering/tightening all the screws at the same time.
Where the 'plastic' chrome had peeled I removed it all and replaced with 1" & 1/2" 3m relflective vinyl, 9005 Blue.
I see this stuff has a 7yr expected life outside.
How is yours holding up?
1TallTXn is offline   Reply With Quote
Old 11-19-2023, 09:42 AM   #23
2016 30' Classic
Sioux Falls , South Dakota
What method did you use to remove all of the chrome. Some flakes off with my thumbnail. The rest is pretty solid. Can you clean and tape over it? How’s yours holding up?
Best Vroominum
2016 Classic 30 RBQ VROOMINUM
2016 Ford F-250 6.7L Diesel Crew Cab ELUKKA
Vroominum is offline   Reply With Quote
T-Molding (Tee Molding) Trouble and Solution! shane_franz Cabinets, Counter Tops & Furnishings 0 07-05-2013 12:09 PM
insert molding tracker Upholstery, Blinds, Walls & Interior Finishes 7 06-09-2012 12:44 PM
Exterior blue trim insert Kajtek1 Exterior Restoration Forum 9 05-08-2008 10:46 AM
Exterior Vinyl molding replacment trilink5 Clearcoat, Exterior Paint & Trim 4 03-14-2007 04:38 PM
exterior vinyl molding dcfl Clearcoat, Exterior Paint & Trim 1 08-09-2003 09:54 AM
