Old 02-18-2019, 11:37 AM   #1
Everything Skylight on Vintage Airstream
hi!
I'm a relatively new owner of a 1965 Safari who needs to replace two skylights.
Does anyone make skylights that will fit with the attachments that open and close the originals? I've attached photos of the equipment.
Could use a reference on where to buy vintage or new skylights that can function as the originals or to be told why using old ones isn't a good idea. Maybe no one makes them to work in the specific sizes or they will leak so just replace... I assume new ones will have to just be permanently attached and won't be able to open?
The outside dimensions of the vertical flanges are 13 3/4 " x 25" and 13 1/2" x13 1/2". I put the measurements on the photos below also. Both skylights are different and the hardware different so maybe a skylight that works with one opener is still available even if the other isn't?
Please advise!!!!!
Denise
ID:	333886   Click image for larger version
DeniseP is offline   Reply With Quote
Old 02-19-2019, 03:33 PM   #2
Hittenstiehl's Avatar
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Vintage Trailer Supply sells those Astrodome's. But not the lifters (yet) you never know they could be researching a retrofit.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-20-2019, 09:21 AM   #3
Thank you!! I'm such a novice the advice helps!
Denise
for the pet who has everything - except an Airstream bake315 The Pet Forum 2 12-17-2019 07:17 PM
skylight gasket, velcro residue on skylight glass basecamper Base Camp 0 06-11-2016 09:52 AM
Vintage 1978 Airstream Sovereign-31ft-NICE!-Everything Works eBay Watch Airstreams on eBay 0 05-04-2012 02:20 PM
1973 Airstream Argosy Vintage Nice! Everything works! HURRY! PRICED TO SELL. eBay Watch Airstreams on eBay 0 11-06-2011 05:00 PM
New to everything Airstream LJS Member Introductions 13 04-02-2008 01:16 AM
