Old 04-03-2020, 08:45 AM   #1
Geogetown , Texas
Electrical Odity
We bought our 2017 25 FB last October and have used it a few time, but wife and I havre been living in it for the last several weeks hiding from society .
Spending this much time in it, we have started to discover a couple oddities. One was the water pump (another thread). The other is electrical.
When we turn on certain lights we get a flicker in the light above the dinette. Iíve also noticed that if the light in the shower is off and I turn the vent fan on or off the shower light will flicker on for just a fraction of a second.
Any thoughts on what might be causing this?
-Dan
Dweyant is offline   Reply With Quote
Old 04-03-2020, 08:56 AM   #2
Ck the sockets for both, loose bulb...bad connection, usually a faulty ground.
It's that time again... Have a great Happyhollowgivingthankmas everyone.
ROBERT CROSS is online now   Reply With Quote
Old 04-03-2020, 10:56 AM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Yup +1
Flickering usually has to do with connection.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 04-03-2020, 11:06 AM   #4
batman's Avatar
1964 22' Safari
modesto , California
Check the wire connections at the terminal blocks for a loose ground or revered polarity. A multi-meter is a good tool to have for electrical diagnostics.
-Dennis
batman is offline   Reply With Quote
Old 04-03-2020, 02:08 PM   #5
2018 25' International
Slidell , Louisiana
As the others indicated, it is likely a slightly weak common ground/negative wire. LED lights using a common ground/negative can flicker and light up due to current fluxes and voltage variations on the common side since it is always connected to the LEDs as opposed to the positive which is switched.
Brian
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 9 02-05-2019 07:38 PM
Electrical probs w electrical to new fridge cooling unit. Surfairstrea Batteries, Univolts, Converters & Inverters 2 05-23-2012 08:24 PM
I have made many electrical changes FrankR Electrical - Systems, Generators, Batteries & Solar 4 10-03-2008 09:53 AM
New electrical in position FrankR Electrical - Systems, Generators, Batteries & Solar 5 05-19-2002 12:47 AM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
