Old 04-09-2020, 08:22 AM   #1
2016 16' Sport
Miami , Florida
Easy start heat pump
I have a 2020 16 foot Caravell. The a.c works great with the Micro Air easy start. Is it ok to run the heat pump on 15 amp service?
The previous 16 foot sport I had only had a heat strip built in the 13500 btu a/c. That could not be ran on 15 amps. I can’t figure out if this unit is a real heat pump or just a heat strip.
Shiny16 is offline   Reply With Quote
Old 04-09-2020, 08:43 AM   #2
2020 Classic 33
Box Elder , South Dakota
It is a real heat pump. You should be fine running on 15amp. Just don't turn anything else on
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 04-09-2020, 08:59 AM   #3
2016 16' Sport
Miami , Florida
Thanks!
Old 04-09-2020, 09:05 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
You should get a little voltmeter to plug in. That will tell you if the unit is drawing too much current. My EMS reads both voltage and amperage. One of those units will tell you when you are drawing too much for the circuit. You are probably plugged in to a fixed base and have the batteries fully charged. If they run down then the converter draws a lot of amperage too.
Old 04-09-2020, 09:29 AM   #5
2018 25' International
Slidell , Louisiana
Looking at the parts manual confirms you have a 13,500BTU Dometic Penguin II Heat Pump. With Soft Start, there is a fair to good chance you can get by on 15A service, but when it starts nothing else can be drawing power, think refrigerator and hot water especially. Inrush may be as high as 18Amp so there is a chance it will trip a 15A breaker especially with a long and/or thin extension cord.
edit: Ooops Im a bit late to respond others beat me to it!
Brian
Old 04-10-2020, 01:14 PM   #6
Donaldo's Avatar
2018 16' Sport
Milwaukie , Oregon
When did A.S. start installing tha a.c. with soft start?
Donaldo is offline   Reply With Quote
Old 04-10-2020, 01:34 PM   #7
2020 27' Flying Cloud
Howell , MI
our 2020 FC 27FBT, with optional 2nd AC/HP, did not come with soft start units. We had our dealer install them before we took deliver.
BandLAir is offline   Reply With Quote
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 24 09-18-2019 08:12 AM
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
