Old 12-28-2016, 11:33 AM   #1
U.S. Navy, Retired
Silverleaf's Avatar
1997 30' Excella
Cumming , Georgia
Duo Therm Penguin heat pump feature
We have a 1997 Excella 30' Classic. It has only one AC unit, and I think it is original. The thermostat lists heat pump as one of the options when I cycle through the modes, but the heat pump setting doesn't appear to do anything. How can I prove that I actually have the heat pump feature? Could it be in the list but not actually installed? I've tried it in cool but not below 40* temps, so it should work. I don't expect the compressor to kick on, but I would expect to hear the fan. Any one have experience with this?
Bill & Barbara
WBAC 3615 AIR 77452
1997 Excella 1000 Classic 30
2018 F250 6.7L Powerstroke
Silverleaf is offline   Reply With Quote
Old 12-28-2016, 11:56 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Whether or not heat pump shows up on the thermostat is, I think, controlled by dip switches in the control board in the inside unit. If that was set wrong, or if the overhead unit was changed and controller not reconfigured, it may be showing Heat Pump even if your unit doesn't support that feature.
I suspect the only way you can find out for sure is to remove the cover from the rooftop unit and read the label to get the model number. An AC tech could probably look at it and spot the reversing valve, and maybe you can. I wanted to find out what size unit was in my trailer but there was no label for the roof-mounted part visible even after removing the shroud from the inside.
Al
Al, K5TAN and Missy, N4RGO
WBCCI 1322
Old 12-28-2016, 09:40 PM   #3
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
As Al said, pop the cover off the unit (4 Large screws, 2 along the front edge one each side). There will be a wiring diagram on the right side towards the front on the electronics box lid. If it shows a "reversing valve" your unit is a heat pump. The reversing valve does just what it sounds like, reverses the operation of the unit to either move heat from the inside of the coach out (A/C or cooling mode) or move heat from the outside in (heat pump mode).
Below is a photo with cover off. White wiring diagram is located towards the front. The reversing valve is shown on the wiring diagram towards the right at the bottom.
Name:	ImageUploadedByAirstream Forums1482986307.594854.jpg
Name:	ImageUploadedByAirstream Forums1482986260.105577.jpg
Boundless Power Systems LLC
Mount Vernon, OH
27FB International / Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Used circuit board for Dometic Duo-Therm 13,500 btu Penguin heat pump. Shayne50 Airstream Classifieds 0 07-09-2015 09:13 PM
Duo-Therm Heat Pump/AC myrna Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-12-2011 09:46 AM
Dometic Duo-Therm "Cool Cat" heat pump/AC unit?? PA BAMBI II Furnaces, Heaters, Fireplaces & Air Conditioning 4 08-19-2010 08:52 PM
Duo-Therm Heat Pump Gael79 Furnaces, Heaters, Fireplaces & Air Conditioning 8 04-23-2010 09:32 PM
