Old 12-28-2016, 07:32 AM   #1
1999 28' Excella
New Orleans , Louisiana
Duo Therm Penguin does not run
Our roof unit will not run at all. No compressor sound or fan. It has not been on for a couple of months but without warning will not work. The thermostat will run the furnace.
Maybe it is toast. I think it is original on our 1999 Classic. We are full-timers so the last 3-4 years it has worked well except we had to have the fan motor replaced.
badkat is offline   Reply With Quote
Old 12-28-2016, 07:52 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Have you verified it is getting power?
MICHAEL
Old 12-28-2016, 07:56 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Check power at the unit first.
2004 Excursion 4x4
Old 12-28-2016, 07:56 AM   #4
1999 28' Excella
We are sorry, don't know how.
Old 12-28-2016, 08:44 AM   #5
HowieE's Avatar
Images: 12
If your unit has a switch that controls the AC and the Microwave check it to see which way the switch is selected. If the Microwave lights you have power to the switch and just changing the switch position should apply power to the AC.
If not power to the microwave check the circuit breaker panel for a tripped breaker.
If you can't verify power that way and you are not able to use a volt meter you will have to have someone check for power at the unit itself.
2004 Excursion 4x4
Old 12-28-2016, 07:24 PM   #6
1999 28' Excella
Everything works but the unit. Where would you put a voltage checker on this unit..inside or out on the roof?
Old 12-28-2016, 07:27 PM   #7
1999 28' Excella
Oh my GOSH it was a breaker..love you!
Old 12-28-2016, 07:40 PM   #8
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
If operated from low voltage, like at a park with old wiring, the breaker will trip.
Al
Al, K5TAN and Missy, N4RGO
WBCCI 1322
Old 12-28-2016, 07:53 PM   #9
1999 28' Excella
thanks
thanks, I am so excited
Duo-Therm Penguin A/C cooney Furnaces, Heaters, Fireplaces & Air Conditioning 5 06-22-2008 07:55 PM
Dometic Duo Therm Penguin gloran Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-20-2007 11:06 AM
Need Dometic Duo Therm Penguin air distribution box gloran Land Yacht/Legacy Motorhomes 1 01-20-2007 11:00 AM
Duo-Therm Penguin odor startrekker2001 Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-22-2003 08:49 AM
Duo Therm Penguin A/C Installation JAG Furnaces, Heaters, Fireplaces & Air Conditioning 1 03-18-2002 10:11 AM
