Old 07-11-2018, 09:26 AM   #1
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Ducted Air - Covers Restrict Airflow
Anyone have a solution to address the restricted airflow caused by the vent covers? When we remove the vent covers the air conditioner adequately cools the interior.
I’m considering drilling holes into the plastic part of the vent covers to enable more airflow. But if anyone has a better solution I would like to replicate that effective solution.Click image for larger version
ID:	316573Click image for larger version
Frank&Mike is offline   Reply With Quote
Old 07-11-2018, 09:45 AM   #2
DKB_SATX's Avatar
Alamo Heights , Texas
Mine work OK if I'm careful about how the vent registers are adjusted. They're SUPER fiddly, because adjusting their direction also often changes how open or closed they are. Once you point them, you often have to readjust the open/close lever.
— David
Old 07-11-2018, 10:33 AM   #3
Registered User
2016 25' Flying Cloud
Fairfield , California
Ditto, discovered after redirecting the outer directional vent the inner open/ close vent had closed. Check to see if that is happening, the open/close moves way too easily.
Mattirs is offline   Reply With Quote
Old 09-13-2018, 09:07 PM   #4
2018 25' International
2002 30' Classic
1995 30' Excella
Ellensburg , Washington
I would love it if Airstream would make a stainless replacement with adjustable louvers. Do you suppose one could ask?
dcineb is offline   Reply With Quote
Old 09-13-2018, 09:13 PM   #5
2019 27' Globetrotter
Salem , Oregon
If you want to spend the money why not try a HVAC dealer. They could probably make you one. Dave
NoResults is offline   Reply With Quote
Old 09-14-2018, 02:39 AM   #6
UncleBad's Avatar
2018 27' Tommy Bahama
Marana , Arizona
I have same question. Have not found replacements. Sent Airstream customer service a couple of emails with zero response.
My thread has link to another thread with a possible solution.
http://www.airforums.com/forums/f427...ts-186900.html
Do post here if you find something better!
2018 27FBQ Tommy Bahama - "Indecision" w/Blue Ox SwayPro, Centramatics, Dual EasyStarts, Airstream Connected, Airtug Trailer Tug HD
2012 F250 6.7 Powerstroke King Ranch - "Earl", Centramatics, Viair On Board Air
UncleBad is offline   Reply With Quote
Non ducted VS Ducted ianburnett Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-01-2012 11:24 AM
Ducted or Non-Ducted A/C tesstoaster Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2012 01:43 PM
airflow elbundi Classic Motorhomes 7 10-05-2009 05:23 AM
airflow for converter JK3500 Batteries, Univolts, Converters & Inverters 2 11-21-2008 05:36 AM
anyone ever balance the airflow on a furnace? john hd Furnaces, Heaters, Fireplaces & Air Conditioning 18 11-25-2003 12:16 PM
