Old 10-08-2018, 09:28 AM   #1
2019 27' Tommy Bahama
Alexandria , Virginia
Door Latch not releasing fully
On the road and the door latch will not completely release from outside. When you open it disengages and opens a quarter inch. Will not fully disengage. Works from inside.
When I have the door open, and engage the lock and open it from the outside the clasp fully opens.
We are reduced to keeping the emergency exit latches loose so my eight year old can climb in and open from inside. He does not mind.
LiveStreamn is offline   Reply With Quote
Old 10-09-2018, 10:39 PM   #2
Santa Rosa , California
Sounds like you’re trying to open the door when the deadbolt is still locked.
-Sean-
SeanWasHere is offline   Reply With Quote
Old 10-10-2018, 05:35 AM   #3
-Sean-
Deadbolt is disengaged, but about the same amount of play.
Convert vintage door latch to modern double rotary latch & strike? Mixter Doors & Locks 5 02-19-2017 09:12 AM
Releasing Parking Brake Laidback1 Sprinter and B-van Forum 2 04-21-2016 11:12 AM
Gas Water Heater - Main burner releasing gas without pilot Gasgano1979 Water Heaters, Filters & Pumps 14 01-25-2015 11:45 AM
Dodge Releasing the 1500 Diesel Half Ton Kevin245 Tow Vehicles 18 02-17-2013 08:48 PM
Installing a Door Knob (Latch or Not to Latch) rslaymaker Doors & Locks 2 11-17-2009 09:52 AM
