Old 08-09-2020, 07:21 PM   #1
2006 19' Safari
Albuquerque , New Mexico
door latch collapse
Returning from camping went to open the 2016 Bambi, and the whole latch came out from the door. Opened eventually with a screw driver on a tab inside the frame. Do I buy knew if possible or try to put all the screws back in hopefully in the right place? appreciate any advise.
humbug is offline   Reply With Quote
Old 08-09-2020, 09:42 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Welcome to the Forums!
If you have all the parts and the screws, and you can't see that there is damage to the threads, then try screwing it back together. I can't imagine it being very complicated. You might also buy some "thread locking" compound and put a drop on each screw so that they don't rattle loose and back out in the future.
If you have stripped threads in the casting, then you are probably going to have to buy a new assembly.
good luck!
Old 08-09-2020, 09:50 PM   #3
2018 25' International
Slidell , Louisiana
Great advice, if nothing's broken bent or stripped out, loctite or super glue (in an emergency) is your friend!
Brian
Old 08-09-2020, 10:09 PM   #4
2007 22' International CCD
door latch collapse
Do use the non-permanent Blue Locktite compound.
Iíd stay away from super glue as well. Itís too permanent.
The permanent red stuff is not a good idea if the lock ever needs repairs in the future. Itís really, really permanent!
Note that using more locking goop IS NOT better in this case. A small drop on the screw threads before you insert it and tighten gently will do it nicely.
Roof Collapse Roadrunner Winterizing, Storage, Carports & Covers 2 03-02-2010 06:53 AM
How will an economic collapse affect the RV/TT lifestyle? innjtown Off Topic Forum 235 10-24-2008 05:29 PM
Minneapolis Bridge Collapse: forum connections?? maxandgeorgia Off Topic Forum 7 08-02-2007 06:43 PM
Rear end sag, then collapse on maiden voyage ;( bambam Repairing/Replacing Floor &/or Frame 15 12-02-2005 08:14 AM
