The external centerline door trim (not sure what the official description is) is not adhered to the door at the rear end. My immediate concern is the potential for water getting into the inside of the door. It looks like there is a rivet at the end (in the photo you can see the rivet hole in the skin, but the rivet is not visible), and it looks like this trim is/was sealed where the top edge meets the external skin.
Does the center of this trim pull out to expose the attachment rivets?
In a few days I'm heading out for 3 to 4 weeks in the trailer, then at the end of May I will be out in Jackson Center for my final warranty visit. I will add this issue to my list for them to fix, but I'm concerned about what happens in the meantime. Do I need to seal this to eliminate the potential for water getting into the internal workings of the door?
I've looked online for a squeeze tube of Sikaflex or Dicor in clear, but it seems non-existent; actually, any squeeze tube seems non-existent. Does anybody have suggestions for what I could use, assuming it should be sealed?
I was thinking of these two 3M products:
https://www.amazon.com/3M-05220-Mari...55&sr=8-3&th=1
or
https://www.amazon.com/3M-Marine-520...55&sr=8-6&th=1
The first is white, which is not my preference, but is a fast cure. I would prefer the second because it's black, but it has a long cure time. Are there other polyurethane sealants that a marine supply shop might have.
Thanks in advance for your thoughts and suggestions.
Sorry, can't figure out how to rotate photo.
Mark
