Old 01-20-2022, 04:48 PM   #1
2014 23' FB International
Morro Bay , California
Dometic Refrig Door Facing
I have a Dometic refrig, model RM2351 in our 2014 23' FB International. The decorative wood door facing comes crashing down to the floor. I believe the bracket at the bottom of the door is broken or simply does not hold the weight of the door facing. Has anyone had a similar problem and is the problem the bracket or something else? We have tried double-sided tape to assist the bracket in holding the door facing in place against the door, but to no avail. Is it easy to repair properly if I can get the correct bracket from Dometic?
jcbsurf is offline   Reply With Quote
Backup / front facing camera upgrade jquayle Sprinter and B-van Forum 5 08-04-2013 09:54 AM
Why are some AC shrouds facing the wrong way? robwok Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-22-2012 02:58 PM
A-Frame Jack, front-facing hand crank? Splitrock Jacks, Stabilizers, Lifting and Leveling 5 04-19-2011 07:31 PM
Facing foreclosure, may sell AS MrsGlisten Our Community 3 11-18-2009 07:30 AM
Dexter axles putting them on facing correctly Lothlorian Axles 5 03-17-2009 08:40 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
