Old 09-19-2018, 12:31 PM   #1
2015 19' Flying Cloud
Clermont , Florida
Dometic AC Condensatio
Hey, I have a 2015 FC Bambi and while camping in Miss and Fl , noticed water on the floor under the AC. This is the first time we have noticed this and have been camping this summer in Fl with no noticeable moisture problems. Any thoughts?
Willy Paul is offline   Reply With Quote
Old 09-19-2018, 12:45 PM   #2
A W Warn's Avatar
Two Places , Sticks & Bricks
Is condensate draining through the tube and dripping beneath the trailer? If it is not dripping beneath, and you are getting a flood each time the AC cycles off, could be the drain tube is plugged.
Mud daubers and spiders are notorious for plugging up the condensate drain tubes.
Try to use a shop-vacuum to suck the clog out of the tube.
Or, ream the tube to break up the clog with a weed trimmer string.
Or, compressed air to blow (but this does not clean out the problem)
If the drip is just a small amount, dripping only occasionally, it could be normal. High humidity and high temperature can cause this.
I feel homeless
Alan
Former Airstream Owner
(1973 31' Excella, 1978 31' Excella, 1987 32' Excella, 1999 30' Excella, 2000 25' Safari)
Charging old Dometic Reefer smily Refrigerators 9 09-18-2017 02:50 PM
1961 Dometic Refrigerator - Best Repair Shop? Andy R Refrigerators 18 03-21-2011 08:07 PM
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
dometic 3way refer. will Refrigerators 3 08-23-2002 04:52 PM
Dometic Furnance Help cmgirdwood Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-07-2002 09:34 PM
