Old 02-07-2020, 03:27 PM   #1
2012 25' FB Flying Cloud
Any Town , Mississippi
Domestic Heat Pump Failing and failing and
Airstream Friends,
I am full time in a 2012 25 foot Flying Clout FB. I bought it used from a dealer and have owned it around four years. This is my third AS.
When I bought it the AC was bad and was replaced. A year later that unit went bad. At the time the warranty expired that unit went out. This sequence has happened again and I am having the fourth unit installed under warranty. So in four years four u it’s which two of them I have had to pay for. All the work has been done by an Airstream dealer on the Mississippi Coast.
Any other experience like this.
StanleyE is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
Domestic A/C,heat control box Martin R Electrical - Systems, Generators, Batteries & Solar 1 10-15-2015 06:04 PM
Heat Pump - Replace with an AC or Heat Pump? A W Warn General Repair Forum 32 10-12-2015 02:18 PM
To heat pump, or not to heat pump, that is the ?? MacDad Furnaces, Heaters, Fireplaces & Air Conditioning 16 09-06-2014 09:58 PM
New AC, Heat Pump or Heat strip? firedog 1990 - 1993 Excella 3 01-22-2010 04:23 PM
