Old 03-05-2021, 07:42 AM   #1
Erschm1952's Avatar
2014 Interstate Ext. Coach
Glendale , Arizona
DEF problems
We just had the schedule A service completed on our 2014 Airstream Sprinter, and then traveled about 1000 miles. We checked the DEF because we like to keep it topped off. The DEF was totally full, in fact it was slightly over flowing and dripped down the outside of the hose making quite a mess. Should would be concerned as we do not want to get the dreaded out of DEF shutdown?
Erschm1952 is offline   Reply With Quote
Old 03-05-2021, 07:57 AM   #2
Coloradobus's Avatar
We have 2016 4X4 paasenger sprinter. We get about 14 mpg speeding along at 80. Usually commuting between our two places, one in colorado and one in indio, we get 7500 miles before DEF indicator lights up. We do have a DEF gauge found by toggling steering wheel buttons. Our tank is mounted in the right front fender. Our old van, 2010, the tank hung under chassis behind cockpit passenger seat. We havent determined if tank is 2 1/2 or 5 gallons
Also, Mercedes created some “grace” in response to low def levels. Sprinters Dont Go Into a “limp” mode immediately out of DEF. you get a few turns of the key to start motor unencumbered driving normally before any shutdown happens
JIM n CHRIS
Ď62 Overlander 26 ft. ATW Yeager trailer #5289
"62 Airstream 22ft. ATW Hall trailer #83,í90 SQ Sream, Ď06 Bambi Q/S, Prevost Featherlite 45ft, GMC/ Bigfoot camper
Coloradobus is offline   Reply With Quote
Old 03-05-2021, 08:17 AM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Are you concerned that itís overflowing, not using def to your expectation, or do you actually have some sort of indication light on?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 03-05-2021, 09:18 AM   #4
Erschm1952's Avatar
Glendale , Arizona
We are concerned that it is overflowing and usage is low. No indicator lights have appeared.
Old 03-05-2021, 11:28 AM   #5
AnnaBelle33's Avatar
2021 33FB Classic
Cumming , Georgia
I have a 2019 RAM 2500 Limited. I realize this is not your vehicle; however, maybe there are similarities with DEF.
I noticed when I top mine off, it takes a very long time for the gauge to start showing DEF use. Then after 1,500 miles - it starts going down normally.
Could this be you? Or are you saying itís topped off and after youíve driven 1,000 miles - itís still overflowing?
IG: @AnnaBelletheAirstream
2021 Classic 33 FB
2019 RAM 2500 Limited (6.7 Cummins Turbo Diesel)
WBCCI# 8026
AnnaBelle33 is offline   Reply With Quote
Old 03-05-2021, 03:40 PM   #6
1986 31' Sovereign
Miami , Florida
Sounds like the dealer simply over-serviced your DEF tank. Not an issue unless you encounter freezing temperatures (in that case, DEF expanding as it freezes could damage the tank).
Keep on trucking. I donít think you have a problem.
Sorta new (usually dirty) Nissan Titan XD (hardly paid for)
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Diesel/DEF mileage. ROBERTSUNRUS Tow Vehicles 28 03-19-2014 11:47 AM
Def aa9zz Sprinter and B-van Forum 4 10-03-2013 11:34 PM
Diesel Exhaust Fluid (DEF) Brentsouth Sprinter and B-van Forum 17 04-13-2013 02:18 PM
Hi-Def on the road????? FlaAirstream Full-Timing 2 11-26-2007 06:30 PM
Problems Problems Problems pjzuk General Motorhome Topics 6 09-03-2007 07:25 AM
