Old 07-03-2020, 10:40 AM   #1
Alreddawg19's Avatar
2018 23' Flying Cloud
Redmond , Washington
Controlling condensation
Hi all
We just spent 5 days in the North Cascades with our two kids and two dogs...total of 4 humans and 2 dogs in our 30 ft airstream bunk house.
We kept the temperature between 60-65 degrees which was within 10 degrees or so of the outside. We tried to keep the fantastic fan on as much as possible and the heat ran a little at night to keep the temps above 61.
We kept the vents open. It was a little rainy on/off.
However, we still got a lot of moisture inside, especially around the walls and windows.
What are some tips and things we can do to reduce moisture??
Thanks so much
Alreddawg19 is offline   Reply With Quote
Old 07-03-2020, 11:53 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
We use a massive dehumidifier. By massive, itís not that big but itís larger than the table top model. I think itís rated for 1100 square feet. Fits under the table for storage.
You only need a dehumidifier when running heat.
Some people also is the portable damp rid as well.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 07-03-2020, 07:21 PM   #3
2019 30' International
Pennsylvania , Pennsylvania
We too use a dehumidifier when needed. I think it's a 20 pint, may be a 30. I sit it at the end of the dinette table. Keeps the 30 footer dry. No moisture at all. Empty tank every other day or so.
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 07-03-2020, 10:10 PM   #4
Thanks!
Do y'all use this when only connected to shore power or inverter?
Do you have any recommendations for a good dehumidifier?
Old 07-04-2020, 05:11 AM   #5
Originally Posted by Alreddawg19 View Post
Thanks!
We went to Home Depot and bought a GE 20 pint. Selected it based on size. Only ever used it when on shore power.
https://www.homedepot.com/p/GE-20-Pi...20LY/310574305
Old 07-04-2020, 08:55 AM   #6
2018 30' Classic
We only use this when on hookups. It sounds weird but when we are off hookups and using heat we just end up cracking a window in back or just shutting off the heat and layering more blankets on the bed and switching to flannel sheets.
Got ours on amazon. Just bought based on reviews and ratings. Narrowed down the options significantly.
BigSxyWhtGuy
Old 07-04-2020, 09:47 AM   #7
saraed's Avatar
2016 27' International
North Augusta , South Carolina
Thanks!
I life full time in my 27FB. Iím on full hookups in the cold weather when I need a dehumidifier. I usually only run it when I go to bed or when Iím cooking. I got this one (https://www.amazon.com/dp/B07B8SCPZ4..._pokaFb4WXKCY5 ) last fall and have been very happy with it. It is so quiet I have to look at the screen to make sure itís running sometimes. Since I got it I have had zero condensation build up with as many as 2 adults, 1 teen, and a dog in the trailer at 1 time.
saraed is offline   Reply With Quote
Controlling Humidity/Condensation/Moisture RuththeBambi Full-Timing 21 02-20-2020 01:14 PM
Controlling Bounce Whizzo Jacks, Stabilizers, Lifting and Leveling 12 03-17-2013 10:24 PM
Controlling Black Tank odor thecatsandi Waste Systems, Tanks & Totes 36 05-03-2012 06:49 AM
Controlling humidity Catman6 Full-Timing 23 03-31-2010 02:55 PM
Controlling Humidity chaimemet Dehumidifiers & Ozone Generators 2 06-17-2007 06:07 AM
