Old 05-19-2020, 12:53 PM   #1
1983 34' Limited
GUELPH , ON
Clearance/Marker Light Replacement
Hello all,
I've gone through many of the multiple threads around replacing marker lights and I'm not really getting the answers I need so here goes.
I have an '83 Limited (34') and some of the marker lights are deteriorating. I’m considering replacing with LED fixtures but am ok with original incandescent lamps. I’ve looked at a few models and some I bought had the “drip/weep hole” on the top of the light (based on the entry point of the hot wire through the skin).
I have also looked online at a number of lights that have multiple holes on the top sides and bottom.
Are these ok? Do these require sealing with Vulkem/Parbond or another sealant? Are there lights that have no hole on the top or sides that just allow for condensation to weep out through a bottom hole?
Finally, are gaskets required? Do they help prevent leaking?
passenger56 is offline   Reply With Quote
Clearance/Marker light question groovzilla Lights - Interior & Exterior 5 09-27-2016 09:08 AM
Marker / Clearance light bulb size Dingo Girl Lights - Interior & Exterior 3 10-06-2014 07:51 AM
Marker and Clearance Light colors mrcjdunne Vintage Kin 4 10-14-2012 09:13 PM
