RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 10-16-2020, 11:35 AM   #1
2019 16' Sport
La Porte , IN
Cleaning "rusty" spots off vinyl
We have several rusty looking spots on the vinyl laminate floor of our 2015 27FB International that won't come out. They aren't rust, just look that color, and are sprinkled throughout, not concentrated in any one area of the floor. We've started with all purpose cleaner and a scrub brush, then I tried my floor steamer (great for cleaning everything else off these floors but apparently not these rusty spots), and then vinegar and baking soda with a scrub brush -- nothing has touched them. It doesn't look like anything is ground into the floor but more like some sort of reaction the flooring material has had. Has anyone else run into this issue? And were you able to get them out? Thanks!
TotalBettyB is offline   Reply With Quote
Old 10-16-2020, 11:58 AM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard 👍
I would first....Make sure the spots are not caused by the subfloor being wet.
I have this in the AS tool kit...handy for probing for moisture.
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Mary-Jane....'cuz 2020 sucks"
Tahawus
Old 10-16-2020, 12:37 PM   #3
Silvr_Bullet's Avatar
42 2' 27" N / 74 7' 6" W , US
There are moisture meters that do not require puncturing holes in the vinyl floor to determine if moisture is a problem, available on Amazon.
Silvr_Bullet is offline   Reply With Quote
Old 10-21-2020, 08:48 AM   #4
David Logue's Avatar
2008 25' Safari FB SE
Allen , Texas
rusty spots
I had the same problem near the door area. I tried everything to get them out. Finally I'd had enough and pulled the linoleum up, from the plywood. What I found was water penetration plus rusty bolt heads. I cut the ply wood out removed bolts and changed all the flooring with wood look alike linoleum. It was worth it finding the water leaking under and around the door from bad insulation.
David Logue is offline   Reply With Quote
Old 10-21-2020, 09:11 AM   #5
2017 25' Flying Cloud
west plains , Missouri
Floor spots
We had exactly this. Floor rot.. wicking leak from rub rail leak. Act ASAP.
rjack is offline   Reply With Quote
Old 10-21-2020, 09:21 AM   #6
2019 25' International
Providence , Rhode Island
Please link it up.
kittmaster is offline   Reply With Quote
Old 10-21-2020, 11:05 AM   #7
Originally Posted by kittmaster View Post
Please link it up.
General Tools MMD7NP Pinless, Non-Invasive, Non-Marring, Digital Moisture Meter, Water Leak Detector, Moisture Testerup To " (19mm) Deep, Backlit LCD Screen, Visual/Audible Alarms https://www.amazon.com/dp/B00HARYVUQ..._DWfKFbW3AJFGC
Old 10-23-2020, 10:50 AM   #8
2019 16' Sport
La Porte , IN
Thank you all for your help! She's booked for winterization in two weeks so we'll talk to the dealership and get a moisture meter ordered.
Old 10-25-2020, 07:32 AM   #9
Added to my amazon cart, thank you for the information.
Best,
Chris
Cleaning Pipes After a Rusty Situation AIRBULLDOGS Plumbing - Systems & Fixtures 1 09-16-2019 02:07 PM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 08:50 AM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 04:38 PM
'69 sov body diagram? (or "what is this rusty part")? j_c_c Waste Systems, Tanks & Totes 2 10-01-2006 01:08 PM
