Old 02-26-2020, 09:01 PM   #1
ChuckZ's Avatar
1966 26' Overlander
2012 28' Flying Cloud
Waukesha , Wisconsin
Clean my screens?
Ok. I give up. We have a 2012 FC. I cant believe you have to pull the cording to clean the screens. How do you do it?
ChuckZ is offline   Reply With Quote
Old 02-26-2020, 09:09 PM   #2
dznf0g's Avatar
Oswego , Illinois
Huh? My screen material is mounted in frames which unscrew from the window assembly. Can you post a pic of your screens?
-Rich-
Old 02-26-2020, 10:53 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I assume you have the windows that swing open from the bottom, and that the screen covers the whole window on the inside.
So, open the window widely and vacuum out the frame and the outside of the screen, then vacuum the inside of the screen. From the outside use a damp sponge to wipe the screen and the frame, and something in a spray bottle for stubborn dirt like bug poop, etc. While you are at it, use windex or your favorite window cleaner on both sides of the glass, then go inside and wipe down the inside of the screen. Apply Formula 309 to the gasket to make opening it easier to open in the future. Let everything dry before closing and fastening the window.
Hehr windows which were?/are? Used in the basic Safari/Flying Cloud line may have been dropped around 2010. The "SE" Safari also had the big single pane glass, and it probably became more cost effective to make everything with a single style. Hehrs are fixed in place and have small sliders at the bottom of the window. On those, just open the glass and clean both sides of the screen. (Hehr windows are standard on many SOBs.)
Old 02-27-2020, 07:36 AM   #4
2013 20' Flying Cloud
Westerly , Rhode Island
I have a 2013 and have never considered cleaning the screens. Is this a common issue?
smithcreek is offline   Reply With Quote
Old 02-27-2020, 07:43 AM   #5
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
It's not that hard. The screens are attached to the windows with about 10 sheet metal screws. Use your cordless to remove the screws then wash the screens outside.
I did wash mine, a 2013, for the first time last fall. Turned out much easier than I thought it would be.
kscherzi is offline   Reply With Quote
Old 02-27-2020, 09:38 AM   #6
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I basically do what Foiled Again does, clean them in place with a damp sponge. I have a special sponge that is designed to clean screens (had it for years - no idea what it's called anymore). I wipe them down at least twice a summer - amazed at how dirty they get. We use open windows over air conditioning if at all possible.
Kay
Old 02-27-2020, 02:49 PM   #7
Clean one, then decide.
Old 02-27-2020, 03:48 PM   #8
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
Some of mine are dirty as all get out; tried a soft brush & old tooth brush using warm water and Simple Green, rinsed and gently blew the screen dry with my compressor. I think I will buy this today and hope it does a better job on the heavy stained entry door.
Name:	Screen cleaner sponge.png
Mike Leary is offline   Reply With Quote
Door closer and left lean, 2005 30 LY Rolltop Land Yacht/Legacy Motorhomes 3 10-26-2014 05:30 AM
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 12:48 PM
Doing the countertop lean tandemfish Cabinets, Counter Tops & Furnishings 1 11-16-2004 06:19 PM
The lean... SCBrat Axles 5 11-24-2003 12:11 PM
Airstream Lean 72 Excella500 Axles 8 11-12-2003 08:21 PM
