Old 07-08-2020, 08:42 PM   #1
2011 23' FB Flying Cloud
Tigard , OR
Chrome lower Body molding
Our 2011 Flying Cloud has a plastic insert type chrome foil coated molding and the chrome is peeling off. I found a site that sells 100 feet for $210. That is too much to spend on the 10 feet I need.
I am hoping someone might have some leftover or have a better source for this product.
Other than this cosmetic the exterior is perfect.
Stinson.mr is offline   Reply With Quote
Old 07-08-2020, 08:46 PM   #2
2007 22' International CCD
What site did you find?
All of mine (2007) is falling apart as you described. The stuff does not stand up well in our bright desert sun.
Old 07-08-2020, 09:17 PM   #3
waltb's Avatar
2014 25' Flying Cloud
San Luis Obispo , California
Send a message via AIM to waltb Send a message via Skype™ to waltb
Woodland Travel sells the insert by the foot.
2014 Flying Cloud - 25' RB
2016 Tundra
Air# 42643; WBCCI# 3884
waltb is offline   Reply With Quote
Old 07-08-2020, 11:02 PM   #4
Tigard , OR
High Sky RV Parts
Insert Rub Rail Lower Molding Chrome 1" (Roll of 100') 201763-100
217.88 $207.50
1 review
⬤ In Stock
Old 07-08-2020, 11:06 PM   #5
Tigard , OR
Thanks for the resource! Can you provide a link? I looked without finding them.
Old 07-08-2020, 11:06 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Check out this other active thread for insight and a source for a tape segment that might fit your need.
https://www.airforums.com/forums/f53...ml#post2380958
If you want the full 100 foot roll, check out Carid for ~$150:
https://www.carid.com/cowles/protekt...pn-37-715.html
The 30 foot roll is #37-314 at ~$60:
https://www.carid.com/cowles/protekt...pn-37-314.html
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 07-09-2020, 05:22 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I left the molding, cleaned off the 'chrome' and replaced it with reflective RV tape👍
ID:	372345   Click image for larger version
"Any nation that can survive what we have lately in the way of government, is on the high road to permanent glory."
Molly Ivins
"Worry...a brain exercise done when it really wants to sleep"
RLC
Tahawus
Old 07-09-2020, 06:08 AM   #8
2013 23' FB Flying Cloud
Lakewood , Washington
Out-of-Doors Mart sells it by the foot. Prices as of this June
odmrv.com
1/2" 2.19 Airstream Molding Chrome Belt Line 1/2 inch 201912-100
1" 2.99 Airstream Molding 1 inch Chrome Rub Rail Insert 201763-100 (201763-100)
vlaming is offline   Reply With Quote
Old 07-09-2020, 06:39 AM   #9
VTSafari's Avatar
2016 27' Flying Cloud
Monkton , Vermont
I have a partial roll left over. If anyone is interested I can measure what is left. It is the 1" variety.
Bill
2016 Flying Cloud FB
2014 Ram 3500 4x4 extended cab
VTSafari is offline   Reply With Quote
Old 07-09-2020, 09:33 AM   #10
Truckee , California
What width did you use? It looks great-much better than the cheap foil airstreamchose.
Rharter is offline   Reply With Quote
Old 07-09-2020, 09:36 AM   #11
What width did you use? It looks great-big improvement over cheap foil Airstream chose, plus safety factor. Thanks.
Old 07-09-2020, 12:04 PM   #12
2017 27' Flying Cloud
Port Townsend , Washington
odmrv.com
My chrome foil is peeling off as well. This product appears to replace the entire piece of trim. Is that correct? How big a deal is it to remove the old trim?
Thanks!
lkuzel is offline   Reply With Quote
Old 07-09-2020, 12:37 PM   #13
Got your PM & replied
Molly Ivins
RLC
Tahawus
Old 07-09-2020, 03:09 PM   #14
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
I just replaced the lower (one inch) trim on our 2014 23D... I used smooth black instead of the "chrome" stuff. We love the look, and will love it even more when we replace the upper, belt line trim with black also.
Our original trim had to be replaced not because the chrome-looking surface failed, but because it started falling off! When I removed the original stuff I was amazed how poorly it had adhered to the trailer... I pulled it off without leaving behind a trace of adhesive... It just wasn't stuck worth a ****.
ID:	372385   Click image for larger version
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 07-09-2020, 05:56 PM   #15
Hampshire , Illinois
Chrome trim
My 2013 Sport 22FB did the same thing. Clean the trailer behind the trim and the back of the trim with some Acitone, then apply some exterior double side tape. That fixed mine
Tom Moquin
debfm is offline   Reply With Quote
Old 07-10-2020, 05:53 AM   #16
Thanks!
Trim is in seamless sections, broken up by door, wheel wells. Old trim will peel off with little effort once you get it started. I used a plastic chisel to keep it moving. Clean up the old tape residue with mineral spirits, scouring pad. Cut the new molding with PVC pipe cutter from Harbour Freight. Used a rubber roller to press new molding into place. Only pain in a** area was behind the battery box, had a piece of wood trim that fit for cleaning, pressing into channel.
Old 07-10-2020, 06:04 PM   #17
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Nice!
NOAZRK2690 is offline   Reply With Quote
Old 07-11-2020, 03:01 PM   #18
waynedonald's Avatar
2001 34' Limited S/O
milton , Florida
hi, RFP. Is your bottom molding !" if so where did you buy the molding insert? & can you get different colors?
Thanks, Wayne
waynedonald is offline   Reply With Quote
Old 07-11-2020, 03:54 PM   #19
RFP
RFP's Avatar
Hurst , Texas
Thanks, Wayne
Hi Wayne...
Yes, my new black trim is 1-inch wide. The manufacturer is Trim-Gard (a Canadian comany). The product I used is their part number 8002S.
Trim-Gard does not sell direct, but their guy in Sales will happily tell you who your local dealer is (I talked to "Paul").
As for colors, I'm not sure, but Paul could tell you.
Their website is: http://trim-gard.com. ... Give them a call.
Robert
And some stuff
Old 07-12-2020, 11:44 AM   #20
milton , Florida
Thanks, Robert For the information, I just checked & they have difference colors so I will
give them a call tomorrow. I like the look on your A/S. Thanks for getting back to me,
have a great day. Wayne
Chrome replacement molding rkd718 Airstream Classifieds 4 07-08-2020 11:00 PM
3M Chrome Molding for Beltline and Fender-levels Brown Trout Airstream Classifieds 1 07-08-2020 08:48 PM
T-Molding (Tee Molding) Trouble and Solution! shane_franz Cabinets, Counter Tops & Furnishings 0 07-05-2013 12:09 PM
To chrome or not to chrome Kiah Upholstery, Blinds, Walls & Interior Finishes 9 11-22-2007 02:26 PM
