I have not a clue, but I'll give you a clue.
Find the water tank fill port on the outside, now make a note of where that is from front or back of trailer. Go inside on the same side as fill and look for a storage area or under a something with a slightly raised section with an access panel. Example in mine it's in the closet under a raised panel.
