Old 06-17-2017, 11:11 AM   #1
1972 31' Sovereign
Princeton , New Jersey
Cable from Airstream
I have a '72 31' Sovereign. The original cable from the Airstream to my 2015 F-150 is not compatible on the truck side. Do I need an adaptor or a whole new cable. And if so where do I get one?
DonPowell64 is offline   Reply With Quote
Old 06-17-2017, 01:33 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
Best to upgrade the umbilical to current connection. Since this is an "older" AS, there is no telling if the connection has been modified... now is the time.
Get a few pics of the setup... on AS umbilical.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-17-2017, 02:55 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
You probably have the older 6pin round style. If the chord is in good shape, installing a new 7-pin style plug on the truck end is not a big deal. I had to do it on my 68 Trade Wind. If you do change the plug, just be sure to check each wire's function. Wiring diagrams for which pin does what are readily available. I did have to change a couple of connections at the trailer end of mine so that the plug and truck wiring and the trailer all were in synch. and would conform to the current industry standard.. That way if someone else pulls the trailer all the lights trailer breaks will work as they should.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 06-17-2017, 02:56 PM   #4
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
The "new" 7 pin cable is what you will see on pretty much any tow vehicle these days. You can get a connector and wire it your self or get a pre made cable. Both are available from a bunch of places. I'd phone your local parts outlet first.
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 09:16 AM
Ethernet, cable, internet for 09 airstream tmarquis Computers, Internet & Satellite 18 03-25-2009 07:59 AM
Spedo cable adapter. SebastianD Airstream Motorhome Forums 1 09-14-2003 07:07 PM
Argosy throttle cable mcneon Mechanics Corner - Engines, Transmission & More... 7 08-24-2003 10:17 PM
accelerator cable islandvu3@cox.net Airstream Motorhome Forums 1 05-27-2002 12:02 AM
