Old 04-05-2020, 12:06 PM   #1
2015 27' FB International
Bug screening for rooftop Dometic a/c
Has anyone tried lining the inside of their Dometic a/c unit cover to keep bees From entering all the holes and nesting?
Sacobb75 is offline   Reply With Quote
Old 04-05-2020, 12:57 PM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I used a bigger mesh, plastic, to keep birds out. Seems to work fine. I used construction adhesive.
Larry
lsbrodsky is offline   Reply With Quote
Old 04-06-2020, 10:32 AM   #3
Sounds good. Thank you!
Old 04-06-2020, 03:48 PM   #4
2020 23' Globetrotter
Savoy , Texas
I used a larger ac cover and a tube filled with sand. DW sewed the tube and I put the sand in it. See the attached pictures. The tube is long enough to go all the way around.
ID:	365067   Click image for larger version
SpinWhite is offline   Reply With Quote
Old 04-06-2020, 03:53 PM   #5
Savoy , Texas
Tried to rotate the picture
ID:	365069   Click image for larger version
Old 04-06-2020, 04:14 PM   #6
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
I got mud daubers in my AC last winter when I was in TX for several months.
This year I went back to the same place with plans to remain stationary the whole time. I got screen material from a hardware store and laid it over the whole AC unit. I fastened it with 3M stucco tape. This lasted the whole time I needed it (over two months) and the tape came off cleanly. (I did not attempt to travel with the screen in place).
The tricky part was that the only screen material I could find was screen door size--long enough but not wide enough. I sewed two pieces together to make what I needed.
SSquared is offline   Reply With Quote
Screen room or screening aa9zz Sprinter and B-van Forum 77 06-07-2022 09:04 PM
Screening! MyNancy1977 Windows & Screens 10 05-20-2014 05:21 PM
Best choice for replacement screening Jim in Pima Windows & Screens 5 03-30-2013 07:48 PM
Looking for plastic/beige screening sailaw Windows, Doors, Locks & Vents 2 01-25-2013 05:35 AM
Re-screening BillTex Windows & Screens 9 06-01-2007 10:56 AM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
