Old 09-19-2020, 06:41 PM   #1
2020 30' International
Ingleside , Illinois
Black tank valve handle and rod missing
Got to our campground this evening and started to set up. Then I see that the rod and handle that you pull to open the black tank is gone. The gray tank one is still there. Do they screw in and out. I assume I can use the Gray tank one on the black tank? How do I keep this from happening again?
JohnandDonna is offline   Reply With Quote
Old 09-19-2020, 06:44 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
Mine were riveted on.
CRH is offline   Reply With Quote
Old 09-19-2020, 07:11 PM   #3
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Mine is riveted on but I could still pull the rod closest to the tank as a temporary solution. Sorry to hear this.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Waste valve handle and rod pulled out of the valve BarnacleBill Waste Systems, Tanks & Totes 23 11-04-2022 06:48 PM
Black tank valve ext. Rod Lthrncktrvlr Waste Systems, Tanks & Totes 22 11-12-2019 06:56 PM
Black water dump valve push pull rod missing firetech51 Waste Systems, Tanks & Totes 2 08-26-2009 08:44 PM
