Old 09-30-2017, 02:53 PM   #1
2012 30' Classic
Wildwood , Missouri
Black Tank Release Valve
Left rear tire blew on our 2006 Classic on our way home from Swiss Rally. When the tire blew, it damaged the black tank handle and stem. Of course the tank is 3/4 full (we were going to dump at next campsite). Any idea how difficult it would be to replace that valve and stem? Thanks.
kswelsh is offline   Reply With Quote
Old 09-30-2017, 03:12 PM   #2
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Hopefully you can still pull it to dump? Never done so or even looked at mine but was under the impression the valves can be rebuilt in place. Let's hope so.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 09-30-2017, 03:58 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
If the valve stem that goes into the valve body is not damaged, it will be easy(ish) to repair. You could also grab onto the valve stem (carefully) with vise-grips to pull open the valve and dump the tank.
If you cannot grab onto the valve stem or it is jammed, you are going to have a real mess on your hands (pun intended)...
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
Propane Line quick release valve set up fmacmaster LP Gas, Piping, Tanks & Regulators 1 03-27-2013 07:31 AM
Leaky Black Water Release Valve gypsygirl1 Waste Systems, Tanks & Totes 4 12-12-2012 04:20 PM
Pressure Release Valve - Replacement lebolewis Fresh Water Systems 14 01-04-2010 11:17 AM
cleaning up toilet tank release handle CindyH Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
