My handles are adjustable. What you have to determine is, is the valve closed and the handle needs adjusting, or is there something in the valve that is keeping it from closing? There is a nut on the wire side of the handle. Loosen it and the handle will turn on the threaded rod. You may be able to shorten the cable enough to get the clips to lock. If not, it is probable that there is something stuck in the valve.
