Old 01-04-2017, 08:17 AM   #1
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Black Caulk -Eddie Bauer
The caulk around the E.B. wheel wells os getting really bad. What should I ise to replace it?
Paula
Old 01-04-2017, 09:50 AM   #2
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Is this inside the wheel wells or outside?
If inside the wheel wells I would use Sikaflex 221 which is available in black, gray and white. I have used this caulk and is easy enough to work with.
If outside you could probably still use the sikaflex but I would use some blue painters tape, small caulking tip and a steady hand.
Use a nitrile glove and strike the caulk joint with mineral spirits.
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 01-07-2017, 08:23 AM   #3
Kemblkr's Avatar
2003 22' International
South Bend , Indiana
X2 on the Sikaflex 221. Available on Amazon and other places
Kemblkr is offline   Reply With Quote
Old 01-07-2017, 08:37 AM   #4
TRIPPPIN's Avatar
Southwestern Ontario , Ontario Canada
Send a message via MSN to TRIPPPIN Send a message via Yahoo to TRIPPPIN
I assume you mean the part between the black plastic wheel opening and the alum skin. I used black urethane on mine. Can't remember the brand. If you can't find it a windshield shop will carry it.
TRIPPPIN is offline   Reply With Quote
Old 01-07-2017, 09:08 AM   #5
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Sikaflex 221 (available in white, grey and black) is the best all around caulk for joints where aluminum is involved. It's available on Amazon.
Bob Martel
WBCCI# 5766
Picture of an Eddie Bauer on the back cover of a semi annual Eddie Bauer flyer BassCan Airstream "In the News" 0 06-18-2016 08:11 PM
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
25 FB Eddie Bauer :: 2012 Airstream Eddie Bauer Jennybeth Airstream Registry Discussions 0 09-26-2013 06:28 PM
Eddie Bauer :: 2012 Airstream Eddie Bauer 25' FB screamstream Airstream Registry Discussions 3 12-12-2011 03:00 PM
