Old 05-29-2023, 07:52 AM   #1
la nomade's Avatar
2018 22' Sport
Airstream Coach - Other
ancramdale , New York
best glue
bottom trim is loose ..which is the best glue to fix that?tried to post photo did not figure out how..too complicated
la nomade is offline   Reply With Quote
Old 05-29-2023, 08:45 AM   #2
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
When my lower trim became loose at one end, I used a heavy duty double stick tape (found it at Lowe's). If you use glue, you will probably regret it when it comes time to replace the faded trim as many of us have had to do.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 05-29-2023, 09:25 AM   #3
CRH
1995 25' Excella
xxxxx , xxxxxx
Goop brand adhesive will hold it. It is also easy to remove later down the road.
CRH is offline   Reply With Quote
Old 06-05-2023, 01:42 PM   #4
HAschner's Avatar
2012 20' Flying Cloud
Richardson , Texas
I’ve used many, but the flex glue adhesive you see advertised on tv (bought mine at Lowe’s) has worked well for me
__________________________________________
Henry - "experience is what you get..... right after you need it."
HAschner is offline   Reply With Quote
Old 06-05-2023, 04:58 PM   #5
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I use 3M Trim Adhesive
https://www.3m.com/3M/en_US/p/d/b40069437/
GCinSC2 is offline   Reply With Quote
Old 06-08-2023, 05:27 AM   #6
la nomade's Avatar
2018 22' Sport
loose trim
followed your recomandation and used the tape,,not glue and it worked well,its holding it in place thank you all
Old 06-09-2023, 09:19 AM   #7
HAschner's Avatar
Richardson , Texas
I recently chose a different approach. I used a wire brush to remove the loose foil and faded trim. I used the flex glue I mentioned earlier to fix the loose trim. Then masked off the trim with newspaper and painters tape, and painted with rustoleum Chrome spray paint. Looks like new, and $20 instead of hundreds to replace it. Very pleased, even if I have to do it yearly
Best Adhesive for Glue Down Cork Flooring Alsupp Floor Finishes 7 07-15-2015 03:56 PM
Glue or not to glue carver 1 Floor Finishes 15 06-15-2015 06:12 AM
Glue or clamp flange to black tank? pilgrim_still Waste Systems, Tanks & Totes 12 03-11-2010 07:08 PM
Tambour Glue? 74Sovereign Cabinets, Counter Tops & Furnishings 10 10-04-2002 03:05 PM
