I have been working on my 1979 sovereign for a bit now. Took the belly pan off to get better access to fixing the frame. Now I am trying to get the new belly pan that I ordered on. I am not sure if I am using the right size bit to drill the holes or not. I have read 3/8 bit to use, but it seems to big. I can’t get the rivet to pop and hold. Thoughts?
Did you save the old belly pan so you can measure off it?
2014 Ford Explorer XLT with factory installed Tow Package.
The rivet shaft is really close to 1/8" - 3/16" (look at the photo with the measuring tape)
Buy the rivets first, measure them to determine the proper drill bit size.
The rivet should fit snuggly into the hole. https://www.youtube.com/watch?time_c...&v=yuJqCtSrad0
Alan
