Old 11-09-2017, 10:24 AM   #1
2008 27' Safari FB SE
Eugene , Oregon
Beep is driving me crazy
I just picked up a wonderful 2008 safari se 27fb
Everything was working great when I brought it home but after running the furnace for a whil, it is hooked up to shore power, I have a beep every minute or so. I checked the carbon monide detector and the smoke alarm but it is not that. I am out of propane, but I cannot locate the source of the beep.
Please help out a newbe.
Robmar is offline   Reply With Quote
Old 11-09-2017, 10:44 AM   #2
2000 30' Excella
Toledo , Ohio
Check the date on your propane detector they have a life cycle I think it's 5or 7 years
woodfox45 is offline   Reply With Quote
Old 11-09-2017, 10:49 AM   #3
Eugene , Oregon
I wii check, where would I find the propane detector
Old 11-09-2017, 11:19 AM   #4
2007 22' International CCD
Usually mounted low, in a non-traffic area. Plastic box-like gadget about 4x5x2 or so. Mine is fastened to the rear of the dinette bench box that has the power panel in it.
Probably has a blinking LED on it and (grin) making beeping noises...
They are usually hard-wired to the battery, and that's why it is so stubbornly noisy...
Old 11-09-2017, 11:25 AM   #5
Sag Harbor , New York
Check your owner's manual, which has a lot of other helpful info you should know, especially about winterizing your AS when freezing weather hits.
Welcome to the forum!
Peter
Old 11-09-2017, 11:29 AM   #6
Eugene , Oregon
Found it
Found it the yellow light is on showing fault
Does that mean it has to be pep laced and if so how do you disconnect it the wires are soldered in on the unit and and I do not see any connectors. Is this a part I need to go to my local dealer for
Old 11-09-2017, 11:36 AM   #7
Half a Rivet Short
2022 Interstate 24X
Carlisle , Pennsylvania
Hi
Propane detectors are a pretty RV specific thing. You are unlikely to find them anywhere other than a dealer. Once you see the new part, the hookup should be pretty easy to figure out ( = no, it's not soldered in).
Old 11-09-2017, 11:39 AM   #8
http://airstreamsupply.com/Propane-S...itor-512539-01
http://www.campingworld.com/category...-detectors/152
You could call the AS dealer a little south of Portland for guidance. Not sure if you have one in Eugene?
Peter
Old 11-09-2017, 11:41 AM   #9
"Cloudsplitter"
"You don't know where you've been until you leave, enjoy life" RLC
Old 11-09-2017, 11:52 AM   #10
Eugene , Oregon
Thanks for the help got it fixed
Old 11-09-2017, 01:28 PM   #11
Good news! Very quick. Is there a reset button?
Peter
Mysterious beep beep beep Hammertime Sprinter and B-van Forum 8 04-02-2016 02:22 PM
High-pitched beep Farmer Dan Sprinter and B-van Forum 8 04-19-2014 02:48 PM
"Beep Beep" was the Sound Frank&Mike Electrical - Systems, Generators, Batteries & Solar 12 06-28-2013 10:13 AM
Inteli-Power 9200 beep beep beep..ahh! MonaxLisa Batteries, Univolts, Converters & Inverters 16 08-15-2010 02:33 AM
No beep beep kepko Land Yacht/Legacy Motorhomes 1 05-12-2009 06:01 PM
