I would and have...
Use
Marine Tex /
MT and toothpicks. Put some of the Marine Tex in the hole, coat the thin end of the toothpicks, insert as many as possible into the hole and rescure. You could also use the
3m 5200 to secure your reinforcement block to the frame. Apply to the face and frame and reattach.
I have used the MT many times to repair stripped wood screws on the AS, along with 5200 to bond and caulk leaks. Excellent results👍
Addendum...it just occurred to me.
JC has started to use balsa cored plywood.
Which doesn't lend itself to being screwed...nice choice.
Thru attachment with backing may be needed.
I recommend DIY, you will do a much better job. 😂
After all JC
screwed it up in the first place. 👎
