Old 03-27-2020, 03:50 PM   #1
Rick
Oro Valley , Arizona
Battery Shut Off Switch
My 2017 Flying Cloud has a shut off switch located on the light switch panel immediately inside the door. This does not turn off all electric as there is still a drain on the batteries. Does anybody know how to hook up a BATTERY SHUT OFF SWITCH for my unit?
It has two 6 volt batteries. I have tried a "screw off" thing on the battery post with no luck so I have to disconnect all cables going to the negative posts on both batteries when I put it in storage.
thanks,
Rick
wampler is offline   Reply With Quote
Old 03-27-2020, 04:27 PM   #2
Mollysdad's Avatar
The USE/STORE switch inside the door is not a real battery disconnect.
The best way (quick and dirty) is doing what you did, remove the terminals.
The fancy pants way is what I did, posted on my blog.
https://www.airforums.com/forums/blo...sconnect-3036/
I have two 12v. batteries in parallel, but the idea is the same. Your batteries are in series.
Battery Shut Off Switch wampler Electrical - Systems, Generators, Batteries & Solar 19 04-20-2020 08:35 PM
Converter shut-off switch - 2005 Classic Pahaska 2001 - 2005 Classic 5 08-22-2009 06:40 AM
Gas shut off valves Sneakinup Water Heaters, Filters & Pumps 1 02-04-2004 10:19 AM
1986 AS 345 MH Magic Chef Shut off Valve? Jim Tyrney Stoves, Ovens & Microwaves 2 10-14-2003 01:48 PM
Shut off valve, 1992 30' Motorhome dwc Mechanics Corner - Engines, Transmission & More... 0 07-01-2002 04:50 AM
