Old 09-20-2020, 02:11 PM   #1
2018 25' Flying Cloud
Hunt , Texas
Battery Disconnect Switch - HELP - Stuck in Store mode
'18 Flying Cloud 25'
HELP! Stored trailer a month ago. Now ready to pack up for a trip.
Connected to shore power, but will not switch from "Store" to "Use" Nothing works.
When I hold the switch in the "Use" position, the lights will turn on. The toggle switch will not stay in the "Use" position.
Update:
I cycled the inverter, and then the system would stay in the "use" position.
Something is still wacked. So suggestions would be appreciated
tomamsco is offline   Reply With Quote
Old 09-20-2020, 02:35 PM   #2
2018 25' International
Slidell , Louisiana
Since it goes to use when you hold the switch the relay is good and the mechanism is not frozen but the spring loaded articulation is stuck and the rod does not flop to the side to hold it "on". You can rap on the body of the relay while someone cycles it on and off to see if you can free up the articulation point and spring. Try it several times first soft and then with a bit more conviction (If you break it you can always bypass the relay by bolting all the lead and load wires together). If that does not work bypass it and order a new one. Amazon sells it for about $35.
Edit: to be clear the relay is by the power center usually bolted to it. It is nowhere near the remote Use store switch. Don't rap on the switch or a new one is in your future.
Brian
Old 09-21-2020, 01:43 PM   #3
Hunt , Texas
Thanks Brian, sadly the relay tripped sometime over the last few hours. Was working yesterday no problem. This morning: no power switch won't even cycle the power on and off like yesterday.
Old 09-21-2020, 04:56 PM   #4
Hunt , Texas
Help. I think Brian nailed it. But where is the relay? Im stranded!
Old 09-21-2020, 05:43 PM   #5
Slidell , Louisiana
The relay is almost always screwed to the back of the power distribution center. Can you access that? Also since yours is at least working, have someone press the switch and you will be able to track it down from the sound of the solenoid.
Edit: sometimes it is near the 12VDC bus bars. I have a FBT. it is on the power center under the curbside mattress.
Brian
Old 09-22-2020, 08:28 AM   #6
Hunt , Texas
Old 09-22-2020, 09:18 AM   #7
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
On my 25 FBQ the relay is all the way forward by the 12v bus bars, as Brian suggests.
Larry
lsbrodsky is offline   Reply With Quote
New AGM Batteries drain in store mode less than a week AJMattern Batteries, Univolts, Converters & Inverters 30 03-22-2019 03:18 PM
Red Light Still on in Store Mode - Battery Disconnect Switch Sammy99 Batteries, Univolts, Converters & Inverters 5 03-16-2018 12:23 PM
"Store" Mode billrector Electrical - Systems, Generators, Batteries & Solar 104 12-23-2017 02:42 PM
Refrig in battery disconnect mode submirj Refrigerators 15 10-01-2016 10:38 AM
Solar charge batteries in "store" mode? Zybane Electrical - Systems, Generators, Batteries & Solar 3 05-26-2016 11:35 PM
