RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-02-2017, 11:46 AM   #1
2005 28' International CCD
1968 24' Tradewind
Alexander , Arkansas
Astradome repair ideas...help please..63' Overlander
OK so the previous owner apparently had some issues with the Astradome. He chose to cover with sheet metal and screw down with self tapping screws. From the inside it looks like he cut the flanges off at their base to make it as flat as possible.
My ideas are .......
1. Remove sheet metal patch... fix/fill holes from screws and then put a large Lexan Skylight over the original opening. Would of course not look stock which is a downside.
2. Remove sheet metal patch... possible put a larger Aluminum patch around original hole and create a new flange for original type Astradome cover.
Any thoughts or ideas appreciated...
Name:	Airstream roof patch.JPG
Endl is offline   Reply With Quote
Old 08-02-2017, 02:59 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
What's already there doesn't look stock, either. No net loss in my opinion.
Besides, retaining the stock appearance only matters if you're doing a restoration to factory original. But if all you want is a return to functionality, almost anything has to be an improvement over what you've got. I say go for it!
Another Hehr lifter question for the Astradome grayling Roof Vents, Skylights & Fans 8 01-27-2015 01:06 PM
ASTRADOME Fiberglass Vent Cover for 1956-1965 Shan Airstream Classifieds 0 12-03-2013 12:25 AM
Astradome - did I order the wrong one? jessejane Windows, Doors, Locks & Vents 9 08-30-2013 06:07 PM
Astradome Installation Twinkie Roof Vents, Skylights & Fans 9 03-14-2008 08:10 AM
Astradome vent cover cookeville34 Roof Vents, Skylights & Fans 4 11-28-2006 06:42 PM
