All the lights in the trailer are designed for
12 volt. You only have a 30 amp service in the trailer from new, so I would upgrade the
12 volt converter to a new 4 stage. A/C and fridge run on 120 volt now, but require
12 volt for controls. You must keep 12 volt or replace the A/C and fridge with new dedicate house units. To rewire the lights to 120 volts would be a big cost and probably not worth the effort. Anything is possible, it only takes $$$$. In a trailer with only 30 amp, you cannot run the A/C and a larger microwave at the same time. The same goes for a 120 volt hot water tank and running the A/C at the same time. JMHO
