I suspect a small leak from this area Im talking about the sheet metal the bracket rest is attacked too Im not sure if its attached with just adhesive caulk or mechanically fastened any input would be helpful before i do any rip and tear
I have a 2005 Safari, I just replaced my old antenna with a new one. I removed the old bracket, it was held down with adhesive tape. Didn't need it anymore.
I took mine off a 1986 and it was riveted with large quantities of caulking over top. I buck riveted an aluminum cover over the hole. The interior is out. Lots of wires as in the main harness travel under that item and the moisture had done nasty things to the electrical.
