Old 10-20-2021, 10:19 PM   #1
Thousand Oaks , CA
Alde heat two questions
2018 classic 33
When using only electric should the system keep the temp at 70 degrees, when it's 30 outside? Or do you need to supplement with gas.
Foward bedroom is usually 5 degrees cooler. How do you get the temp to be the same as the rear.
candrews768 is offline   Reply With Quote
Old 10-21-2021, 12:07 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
System works better with propane and electric both on especially if its that cold outside. Ensure you also have electric 2 on priority if youre on 50amp service.
For temp differences, they will always exist in all trailers. Alde gets it within 5 degrees. You can try and set up a fan to move the air a little more or use your heat pump only in your room? Heat pump will not work below 40 I believe though.
Usually I hear that the bathroom is cooler in the 33 because the towel bar is at the end of the loop where the towel bar in the 30 is near the beginning of the loop.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Alde overheat red hot and empty alde tank Alreddawg19 General Repair Forum 2 10-14-2021 09:19 PM
First Alde 3010 boiler to Alde 3020 boiler and Alde flow upgrade Sparr 2016 - Current Classic (all lengths) 64 08-15-2021 07:36 AM
ALDE HEATING SYSTEM FAILURE- Alde glycol discoloration and vent discharge JimskyD 2016 - Current Classic (all lengths) 50 05-25-2018 08:48 AM
Problem with safety valve popping between Alde flow and Alde paul.kukstis 2016 - Current Classic (all lengths) 7 04-08-2018 07:09 AM
ALDE LP Radiant heat? Zybane 2016 - Current Classic (all lengths) 1 05-06-2016 04:39 PM
